#31 |
Re: Camcorders only
Steve as solo shooters we have to compromise occasionally - I've used this technique successfully for a half dozen weddings this year. Sometimes this also gets guests arriving which I turn into a little time-lapse clip.
#32 |
Re: Camcorders only
I have an AX33 John but it doesn't cut it quality wise against the AX100, it's low light performance lags behind the AX100, I have actually stopped using it
Phil Stanley |
#33 |
Re: Camcorders only
Couldn't agree more. I plan to roll it out on my next Wedding.
#34 |
Re: Camcorders only
Upon reflection, I think my earlier comments about my CX730 and RX10ii were a little harsh.
I decided to make up this comparison image - untouched and ungraded. I think I had an unfairly poor opinion of my CX730 because for me its always a wide 'safety net' shot, and its hard to see much detail when you are so far away from the action. Used on a closer crop on the B&G, it's probably a fair option. Still though, I'm tempted to switch to the a6000 for my wide, using an external recorder (like the Black Magic Video Assist) to avoid the clip length limit. My wife came with me for the first time on Saturday and that is how I got the RX10ii shot - she won't be able to come to every wedding, and I don't do two shooter packages - but boy did it help! Took some pressure off at key moments! In speeches, my wife's job was to stay on the speaker - I used the RX10ii on monopod to get reactions - it was so good to have the freedom to add in reaction shots to the edit without crazy fast pans from my main camera! That said though - auto-focus struggled in this environment since there were so many heads and table top decorations. I'll go manual next time! The have to say, I really like the RX10ii, but I'm worried it's noticeably soft against the A7s and A7sII, and my wife was using it for details shots, which really could have done with a bit more shallow DOF. It certainly has it's place in my bag - just need to get clear in my head when to use which camera! |
#35 | |
Re: Camcorders only
I am a bit surprised though that your rx10II is softer then the A7s, even in 4K compared to 1080p from the a7s? My rx10's (mark1) footage is a bit of a mixed bag, in good light the footage can look gorgeous but in lower light it goes downhill quickly and then I much prefer what my gh3/4 output, also the dynamic range of that camera is limited and windows inside a house often pose a problem as they blow out completely, just look at the 2 shots at 01:33 in the video I in this thread here, the window behind the bride and her sister is just one big white blob. |
#36 |
Re: Camcorders only
The image quality is noticeably inferior to that of the AX100 to the point where you would have difficulty intercutting clips. If you only had one camcorder to film your kids & kittens then I am sure that you would be very happy with he AX33. If you want to use a camcorder professionally then it's worth paying double for an AX100.
#37 |
Re: Camcorders only
Did you shoot 4K with the RX10M2? If not why not?:-)
#38 |
Re: Camcorders only
#39 |
Re: Camcorders only
For the AX100, besides the NP-FV70, you can also use the NP-FV100 which nearly doubles your battery life.
Mark |
#40 |
Re: Camcorders only
He left the forum around the time of the BVE; I only recall cos he instructed some of us to visit it to learn some humility, which coming from him was pretty funny. I think his setup was 3 or 4 fixed cameras he'd cut between, which is probably what Roger was thinking of. The application of just 1 moving camera can combat that effect, plus there's editing. If you're just randomly cutting between 3 cameras as he did, it can look very cctv like, but if you cut to other cameras at the right point, mixed in with moving shots from your main camera, the final results bare little relation to cctv in my opinion.
#41 |
Re: Camcorders only
#42 | |
Re: Camcorders only
Matt |
#43 | |
Re: Camcorders only
#44 | |
Re: Camcorders only
I've yet to use the v-log; I plan to play with this over Xmas when I have more time. I'd need another one to benefit from the colour grading and matching, but I'm finding having 2 GH4's, though 1 is not an 'r' version to be very easy to grade to look identical as I've set up the various camera profiles to match. |
#45 |
Re: Camcorders only
