Vimeo Glitch at DVinfo.net
Old November 6th, 2015, 01:25 PM   #1
Vimeo Glitch
Anyone having an embed problem with vimeo - on Facebook when I paste the link it's showing the file name as the title, even though I have changed it, and the default poster frame, even though I have changed that as well.
First time I've come across this and it's doing it all the time (well for the last 3 upload/embeds)
Cheers
Pete
Old November 6th, 2015, 01:34 PM   #2
Re: Vimeo Glitch
Do you have a plus or pro account?
Old November 6th, 2015, 01:41 PM   #3
Re: Vimeo Glitch
Not happening to me. Just noticed I never posted one from a couple weeks ago & posted it now. States the title I gave it, not the filename.
I'm a Plus, fwiw. But are you just pasting the URL into your post, or the full embed code? I agree, odd glitch tho.
David Barnett is offline   Reply With Quote
Old November 6th, 2015, 01:49 PM   #4
Re: Vimeo Glitch
I'm a plus user and I embed the same way I always have without a problem - this just started today for no apparent reason. I've tried full URL and embed code - I'll have to get on to Vimeo tech support as it's not good - I've also had problems recently with file names with spaces!
Old November 6th, 2015, 01:56 PM   #5
Re: Vimeo Glitch
Maybe they changed some thing to force you to go for the pro account :) I just yesterday went from a pro account back to plus, having pro was not worth the extra cost for me.
Old November 6th, 2015, 05:09 PM   #6
Re: Vimeo Glitch
Vimeo has really good help forums, moderated by people who work at Vimeo. I get an answer within a half hour, almost always. Try that.
Mike Watson is offline   Reply With Quote
Old November 6th, 2015, 05:31 PM   #7
Re: Vimeo Glitch
A search said run the URL thru FB's debugger link: https://developers.facebook.com/tools/debug/ It said to try the "Fetch New Scrape" button after entering the URL.
Could be possible, FB is the one with the glitch, reading old or default cache code.
Old November 6th, 2015, 07:49 PM   #8
Re: Vimeo Glitch
I nearly always have to use the Facebook debugger to get my link to display properly!
Clive McLaughlin is offline   Reply With Quote
Old November 8th, 2015, 03:15 PM   #9
Re: Vimeo Glitch
Facebook Debugger will most certainly fix this (along with a bunch of other related issues, such as image not showing up)
Malcolm Debono is offline   Reply With Quote
Old November 8th, 2015, 05:03 PM   #10
Re: Vimeo Glitch
As an aside, under the embed setttings tab, we are able to embed in HD by default, yet when I select this option and view via Vimeo's website, I see it in standard definition first (via Mobile).
Does this not fall under the bracket of the Embed settings, and if not, is there a way to default all videos via Vimeo to play in HD too?
Craig McKenna is offline   Reply With Quote
Old November 9th, 2015, 01:03 PM   #11
Re: Vimeo Glitch
I actually had this glitch occur for the first time today. Odd because I loaded a few over the last few weeks. This one I did use the 'Choose custom frame' from vimeo, whereas the others I might have either uploaded a stillframe, or used the Random continuously until finding the one I liked. I don't really recall.
Anyway entering the URL in the debugger & selecting 'Fetch New Scrape' did work, and adjust it.
Old November 11th, 2015, 05:06 AM   #12
Re: Vimeo Glitch
I've had that a couple of times - isn't it a facebook problem?
Cheers - Paul M.
www.perbenyik.com
Paul Mailath is offline   Reply
