Dedicated Steadicam Camera
Hi All - Currently I'm using my NEX VG20 mounted on my Merlin for any steadicam work with 14mm pancake lens setup - the downside of this is the flipout screen acts a bit like a sail if there's any breeze plus it's very poor in low light so not much use for indoor work - so my question is - can you recommend a good but not too expensive alternative - I'm looking at spending less than £1K (including lens) but it does need to perform well enough in low light for the first dance
Pete |
Re: Dedicated Steadicam Camera
A sony a6000?
How about the RX10 Peter? since you are a Sony Man? The F2.8 lens should be plenty as you will be at full wide anyway ... I'm using my FZ1000 but because my rig has a dual arm I had to take some bottom sled weight plates and add them on the top sled to get it heavy enough. The bridge camera should be just the right weight for a Merlin and it would match your A7S footage quite well too
Chris |
Ideally I'd like to use my A7s but it would mean quite a bit of lens swapping and I'd like to not have to do that as the sensor is exposed in the same was as the EA50 and I've had tons of trouble with dust flecks so whatever I choose will sit on the merlin all day.
That A6000 looks interesting - I could still use my Sony E-mount pancake lens setup - I'll check out some review - it looks a little light however. |
#5 |
panasonic lumix g6
#6 |
What lens would you pair with that Steve - I'm not too familiar with the four-thirds range
#7 |
I would go with a 14-45 mm, bit better than the 14-42 but both good, the g6 can work up to 6400 iso and maybe a bit of neat video if to grainy. Very light little camera and touch screen and auto focuses lovely. 70d of course but lens 18-135 stm a bit big. There are a couple at the £250 mark Amazon and around. The g7 has come out but around £700. Steve
#8 | |
I still think Peter will be much better of with a a6000 since he already has lenses for sony camera's. |
#9 |
I already have the Sony E-Mount Pancake 16mm f2.8 and the wide converter and the optical quality is OK, so I need to check the low light performance of the A6000 as I will be using this setup for dance floor filming.
#10 |
I have edited some a6000 footage taken in good light conditions and was surprised how nice it looked, very detailed and nice color, didn't get to see any low light shots. From what I have seen the a6000 has impressive autofocus so you might use that in combination with a 50mm f1.4 lens while shooting on a steadicam. There has to be some a6000 users in here that could chime in?
