#16 |
Re: A Cheap shoulder mounted cam needed.
I hear you Roger. I just thought with a QR plate you could get almost instantaneous on and off the rig.
Dave |
#17 | |
What seems to put many people off the cameras, is that it is easy to compare them with similar sized high end cameras. However both the Panny and Sony cams use current technology and facilities that are available on smaller cameras, so there is no particular reason why they should be inferior in image quality to other smaller cameras in the same price range. I certainly wouldn't buy one to impress people, but a spinoff from a bigger camera is that some people make assumptions that they are getting more for their money than when you turn up with something that looks to them like their own camera. In some environments, that may be a secondary advantage. For me though, I would like to see if I would get comparable image quality to other current smaller cams and to run alongside, rather than replace my existing cams for different situations. There must be members on these forums that are actually using one or other of these cameras, rather than comparing them with older versions, so it would be interesting to hear from them as well. Roger I |
#18 | |
Roger |
#19 |
What doesn't get mentioned in the videos is the safety strap that comes with it. With a little practice, I just tried it for the first time a minute ago, it is easy to remove the camera and swing the rig behind you so it hangs at your back, from your shoulder.
I'll quickly describe it so you can work out if it's something you would be prepared to try. I'm right handed, so the rig hooks over my right shoulder. I put my right arm and head through the strap, so both hands were free to operate the camera. I removed (well, ok, I pretended to since I didn't put one on) the camera and pushed the rig round, under my right arm and up my back out of the way. I didn't bother, but a quick tweak of the locking knob and it would have folded up as well. Dave |
#20 |
Thanks for that description Dave and I will be going over to Wex in Norwich at some point, so I will see what they have there as I have never tried one. As they say, 'Don't knock it if you haven't tried it'.
Roger |
#21 |
Hi Roger
I'm not sure if you did anything about getting a shoulder mount camera but I see that Global Media Pro are now listing the AS9000 camera at only a few hundred bucks more than the MDH2 ...Seems to have some neat extra features but still looks a bit of a big plastic box ... Dunno if the UK is listing them ? Panasonic AG-AS9000 (AG-AS9000EN, AG-AS9000E) AVCHD Camcorder PAL |
#22 |
Hi Chris,
That looks identical to the AG-AC8, perhaps with a different designation for your part of the globe. The spec appears to be identical and I think is a more recent update of the MDH2. I haven't made any moves yet as things are getting very busy at the moment, but the Sony MC2500 looks to be possibly a slightly better bet than the two Panasonics, although I have never been a Sony man. Roger |
#23 | |
#24 |
Hi Roger
Yep same model different number! I wouldn't even think about the Sony 2500 I've heard they are awful in low light and with all these cameras I honestly feel you would cry after using the FZ1000 ..they are true entry level cameras with VERY few settings ..you have manual or iA auto ..you cannot change ISO ...just iris and shutter ...even the Panny MDH2 will disappoint you!! Pete? Actually no! I have tried one out (never owned one) and they are very light and a big hollow plastic box and a tiny 46mm diameter lens ..nothing like the EA-50 which is solid... the EVF is also TINY !! I don't think I could use one at all ..it probably tips the scales at a mere 2kg including the lens ..My Sigma lens alone was nearly 1kg!! It sadly looks like a toy and feels like a toy ... probably great for students learning video at school.. that's about all!! |
#25 |
You are probably right Chris, although it would be useful to find somewhere to actually try some of these cameras, not much chance of that though round here. It's on the back burner anyway at the moment as I intend to get another FZ1000 and my Landrover Freelander has just had to be replaced after needing a complete set of injectors that would cost as much as it is worth, to have them fitted. I just traded it in as is, but cost me a fair chunk of money to replace it :-(
Roger |
#26 |
Roger you might get a CVP.com rep to do a demo for you - I got one to Salford to show me the EA50 - They have offices at Brentford and Warwickshire. Less then 2 hours drive for you?
CVP.com |
#27 |
Warwickshire is about 2.5 -3 hours and the same for Brenford. Unfortunately where we are, there are no decent links to any of the main network roads, so A1 is about and hour, so is M11, just makes mileages that don't seem that far in distance take twice as long. Claire is filming a wedding in Warwickshire and will be staying overnight because of the journey time.
Roger |
#28 |
Hi Roger
A mate of mine over East has 2 x MDH2's and had a high lights clips up on Vimeo for evaluation and wanted to know how he could get better IQ and exposure and he gave me a link to the advanced manual. I think if you read the manual you would see that it's very very basic and I seriously don't think it would meet your expectations at all. PANASONIC HC-MDH2 PDF*MANUAL - Manuals - Instruction Manuals I would run thru the manual first before doing any long drives to try it out ... control is way too basic for you! Chris |
#29 |
Why oh why do they make cheap shouldermount camera's like this to give it less features then your average smartphone with a videofunction.
#30 | |
Roger |
