Thread Tools
Search this Thread
#31 |
Re: Adding Movement
Excellent coaching Chris! I typically use a fixed object that I try to keep at one spot in the frame as I walk, wife probably wouldn't appreciate taping the walls! You can practice "slider" and "roundy rounds" similarly. It's rather tricky to "glide" without looking awkward, but that's what you're trying for.... like a ninja cat!
Noa's footage looked quite good, and with Mercali was pretty darn convincing as a "steadicam op". I did note the little "twist" around the vertical axis in the original - I've found that somehow is introduced when I use only one hand, two seems to stop it, I've no idea why! That's where the bearings on "the real thing" come into play and hopefully stop that altogether, but I'm at the point a monopod is "close enough" and far more convenient... the technique just takes practice and concentration! |
#32 |
Re: Adding Movement
Thanks Chris
I had my first practice with the Monopod yesterday before I read this, I was terrible lol. There are some good tips that you have suggested, many thanks Phil |
#33 |
Re: Adding Movement
Phil have a look at this video from Still Motion, some really good ideas
#34 |
Re: Adding Movement
Thanks Andrew that was helpful
Phil |
#35 |
Re: Adding Movement
Interesting points of view on the monopod, I am going to get mine out and see what new things I can do with it.
#36 | |
Re: Adding Movement
I am not questioning anyone's choice of gear. I did find it funny that Came had the warning up about fakes considering who they are. When I buy gear I do try to take into consideration who is getting my money. But the world has changed and things are complicated. The Mom and Pop shops don't even exist anymore. When it comes to Steadycam stuff I get it. When one of my big jobs requires true motion I hire the pro with the high end stuff. That guy would NEVER be me even if I owned that kind of rig, I don't have that level of skill at it. But, like you, I also do small SPC jobs and it is all in my hands. It would not make any sense at all for me to spend more money that I would ever make just to add a few moving shots. So I just ordered a Chinese vest and arm for my Black Bird. Not my first choice of a a way to go but a realistic choice for a small operator like me. The video production bar is quite high for all of us these days. Even as a SPC we are now expected to have the Hollywood motion and big time look in our videos. It is keep up or die. I must learn this new rig because fewer clients are willing to pay for the real pro that specializes in it. If you can't beat um...join um! Steve
www.CorporateShow.com Been at this so long I'm rounding my years of experience down...not up! |
#37 |
Re: Adding Movement
Some great points, Steven. We are constantly trying to do the best we can with limited budgets. Someone else always has a bigger budget, so keeping up is very difficult. Imagine a full length feature shot by one guy who performed all of the roles most feature films require. Yet, each of us wants our feature, or "mini-feature" to be as good.
The documentary travel series, "Deaprtures" was presumably shot mostly by one guy with a steadicam-vest set-up. Hard to believe, considering some of the shots. Still, even with a limited film crew, they did a great job. |
#38 |
Re: Adding Movement
Hey Steve
The actual reason I even looked at it was some guy on the stedicam forum needed to replace the vest on his Pilot and did a quick review on the CAME vest as a possible temporary solution. He ended up keeping it as it was so well made. I was able to shed close to 5kg from my Indian rig by replacing it with the lighter and better made unit and that's a big deal for me! I'm currently looking to replace my wireless mics with 2.4GB systems and I have two choices ...I can buy a Chinese Boya system for $128.00 OR I can get an Audio Technica System 10 for $599.00 Guess which one I will buy??? BTW: If you even thought about the cheaper one you would have been wrong!! I'm sure the $128 one actually works but audio is a big deal for me so the choice has to be an established brand with professional user endorsements. Chris |
