VG 30 lighting issues at DVinfo.net
Old February 7th, 2015, 03:34 PM   #1
Hello I operate a sony vg 30 and find the white balancing has extreme fluctuation with in the same room staying with in the same shot. This shot was under artificial light on a tripod aiming at 1 subject no movie light was used.
Thank you very much
Frank Garrod is offline   Reply With Quote
Old February 8th, 2015, 02:34 PM   #2
Re: VG 30 lighting issues
Hi Frank,
There is a dedicated forum for the VG30 so expect a moderator to move this post. That forum is under Sony NEX Large sensor cameras with E-mount lenses.
Can you give more detail to your question, it does not make a lot of sense? It also sounds like you were going to attach a sample but didn't?
The VG30 is not known to have white balance issues. In fact I have found just the opposite. My main camera is the more expensive EA50. I picked up a VG30 because they share the same sensor and I wanted a small light camera for my Black Bird Stabilizer. I found the VG30 to be the perfect match I was looking for. They must share the same processor too. They function identically in all areas that they have in common.
Steve
www.CorporateShow.com
Steven Digges is offline   Reply
