Camera Sling That doesn't tie up the plate thread? at DVinfo.net
Old August 7th, 2014, 01:05 AM   #1
So yea, I'm shooting handheld a lot these days, but then at times, I'm mounting to tripod/monopod/slider. I'd like one of those slings the togs use for security. Strap goes round shoulder/neck, the camera hangs at the hip.
Problem is all the slings i've seen connect via the plate thread on the bottom of the camera.
I don't want to have to unscrew and attach a plate for mounting.
Does anyone know of a sling that allows a mount plate to be attached also??
Clive McLaughlin is offline   Reply With Quote
Old August 7th, 2014, 01:45 AM   #2
Re: Camera Sling That doesn't tie up the plate thread?
I"m using a b-grip beltholder and a b-grip universal tripod adapter for that purpose.
Old August 7th, 2014, 03:28 AM   #3
Hi Clive,
Many QR plates, certainly Manfrotto ones, attach to the tripod or whatever by a standard 1/4" thread, so you should be able to attach one to a sling with no problem.
Dave
Dave Baker is offline   Reply With Quote
Old August 7th, 2014, 04:01 AM   #4
I think there is some confusion - I'll try to explain better.
The slings normally attach to the cameras bottom thread. Like this.
http://i01.i.aliimg.com/img/pb/363/2...230363_940.jpg
But I need this thread since it's where my plate attaches too for mounting on tripods etc...
Old August 7th, 2014, 11:54 AM   #5
Clive, you are missing the point. QR plate adaptors come in two parts, the top bit that fits to the camera by the usual 1/4" screw and the bottom bit that has a 1/4" threaded hole and attaches to the support by the 1/4" screw the camera normally attaches by, like this one for example, Quick Release Plate Adapter 394 - Plate Adapters | Manfrotto
The idea is, you fit a bottom plate to (say) your tripod, another bottom plate to your sling and a top plate to your camera. You swap the camera from sling to tripod by the flick of a lever. Simple.
Dave
Old August 7th, 2014, 02:10 PM   #6
Op Tech makes sling adapters that use their normal QR attachments on the normal strap lugs. Might look at their line. They even have a "gunslinger" double harness!
I understand the dilemma - handheld gives you freedom, but sometimes you need or want to go on (or off) a rig, be it shoulder mount, monopod, slider, steadicam... If you use one of the Op Tech straps, you can select from various QR ends, various strap configurations, and still put a QR plate in the normal tripod hole on the bottom of the camera to fit your rigs.
Old August 7th, 2014, 03:40 PM   #7
Thanks Dave (Blackhurst) - will take a look!
Dave (Baker) - Cheers for clearing that up - makes sense and could be an option!
Old August 11th, 2014, 05:51 AM   #8
Just wanted to add a thank you to Clive for starting this thread, and to Dave Baker for his brilliant recommendation.
Adrian Tan is offline   Reply
