#16 |
Re: Weddings: I would like to get your take on specific lenses for specific shots....
From my experience without any added lighting, f/4 is NOT good enough for the toasts. 2.8 isn't even good enough for a lot of my dimly lit receptions. Again, this depends on if you use your own lighting and/or don't mind pumping the ISO up pretty high.
#17 |
Hey Sean, whether f/4 is good enough for toasts... Your mileage will vary a lot. Round here, it wouldn't be good enough for general reception/dance floor stuff, but it would be good enough for the toasts, because bride and groom normally are seated at a top table rather than amongst the rest of the guests, and the top table is lit differently by the venue. Speeches are usually done either from the top table, or a lectern beside it.
Always carry extra lighting with you anyway, just in case... Also: it's possible to find a 70-200 f/2.8 IS version 1 that's a lot cheaper than the version 2. Probably around $1200 on eBay. |
#18 |
F4 is good for the reception if you have a C100... maaaybe a 5DM3.
I've used both and the C100 can give usable footage at 10,000 ISO so F4 is definitely usable. You're really pushing your luck with a 5DM3 though. |
#19 |
thats what i've been doing since i got the 5D Mk III (pushing my luck) but as i said elsewhere venues in my area are so badly lit by the Band/DJ or whatever (think of laser lights) it doesn't really matter what light/lens I use these days. i do ask the couples if they can enquire what sort of setup their Band/DJ will have and explain the problems associated with these and possible solutions, so mainly then it's up to the couple.
I'd agree with the view that the 70-200 f/4 wouldn't really cut it in a lot of situations.
http://www.robertcantwell.com |
#20 |
On our C100 and 6D which can both do 10,000 nicely the F4 will be fine. We have the 24-105f4 as it has IS and it does just fine. On the 70D you will struggle. Certainly here in the UK we find most churches f2.8 at ISO 850 is the sweet spot. F4 would require quite a bit more ISO and you will see the noise on the 70D.
We know a couple of people who went for the 70-200 F4 non IS and sent it back within the week to upgrade. Even not touching your tripod you will see the shake from simple floor vibrations. Instances where the IS is needed. Marquee with false floor, tripod on a dance floor and photog walks around, floor shake from vibrations like bass speakers. The usual goto, all rounder is the 24-70 f2.8. No IS needed at those focal lengths and highly versatile. Other popular lenses for the 70D would be the 35mm f1.4 or save and get the f2. On the 70D this equals roughly 50mm.
mintyslippers.com |
#21 |
Tamron 24-70mm 2.8 vc magnificent and i would be lost without it...Sigma 70-200 2.8 is also brilliant... Stabilization a little stiff on a mono-pod but cs6 warp takes care of it.
#22 |
I shoot with a FS100 and my set up has always been 24-105 for pre ceremony, ceremony and main events at the reception. I use the tokina 11-16 on a monopod for general party dancing as well as some prep shots. One of my favorite specialty lenses would be the Canon FD 50 1.4 which gets pulled out a few times throughout the day as well. I just bought a speedbooster so now the 24-105 is a beast but it really makes me long for the 70-200 F4 now, which would be 2.8 with the booster. The tokina looks great at 16 f/2 with the booster but I think I would much rather have the 16-35 now.
Point being the speedbooster and crop factors really change things. My B roll set up is a GH3 set up with all FD lenses, 200 f2.8, 50 f1.4, 35-105 f3.5, 24-35 L f 3.5 all with a metabones speedbooster as well. |
#23 | |
For our aisle camera, we have churches with, literally, 50 meter aisles, and if I'm camped at the front (near the groom), I'll want at least 50mm, but when they don't do a first look, and I'm supposed to get the bride's reaction when they see each other the first time... well, you get it. |
#24 |
I agree, we use 70-200 every single ceremony and in most cases, I wish it were longer! You really need 200mm for a tight shot to capture the emotion well not only from the couple but also the audience's reactions.
#25 |
Prime shooter here! lol!
well we use to rely heavily on our zooms 24-70L and 70-200L but have been using more and more prime lenses specially for preps, b-rolls and reception. Outside of the ceremony, we barely use our zooms. We have 60Ds and Mark IIs and use Canon 50m f1.4 and f1.8, 35m f1.4, 85m f1.8, 135m f2 ,Sigma 30m f1.4 and Helios 55m f2 for preps and broll items. I often use the sigma 30m for slider shots. We also have a Rokinon 14m f2.8 which stays on our glidecam and the tamron 17-50 which stays on the jibcam. We actually just sold our Sigma 70-200 f2.8 and Tamron 28-75 f2.8 since they were just collecting dust. For ceremonies we use 2x 70-200L in the front and the 135 or 85 in the middle. For the the reception we both use 135Ls and have found that to be simply awesome! |
#26 |
Awesome answer Kren!
#27 |
I use a video camera.
#28 |
Hi John
Brilliant answer as always! I also use a video camera but I can change lenses and from the sound of things the DSLR people seem to walk around with bags around their waist snapping on and off lenses every few minutes. If my ceremony is not a candlelit one in a cave at midnight, I keep the camera's stock 18-200 zoom on both cameras ...they do the job ! At receptions that are dark and dingy, I swop the stock lens when I get to the venue to a Sigma 18-35 F1.8 and that stays on all night. I couldn't imagine changing lens all the time I must admit but I guess if you are using primes you have no option. Then again I'm lazy ..if it works don't change it! Chris |
#29 | |
There is a way though to use the right lens for every type of shot without having to exchange lenses all the time and that's to get a separate body for each lens :) |
#30 |
It's quite common for wedding photographers to use two cameras. One camera with a 24-70mm F/2.8 & the other with a 70-200mm F/2.8
