Clamp Advice Please? at DVinfo.net
Old March 24th, 2014, 04:15 AM   #1
Hi all - I've been using these clamps to attach a handycams to stair railings etc, and it's ok but the mounts are a little wobbly
http://www.amazon.co.uk/gp/product/B...?ie=UTF8&psc=1
I'm looking to replace them with something of a similar size but better engineered - any advice?
Cheers
Pete
Old March 24th, 2014, 06:47 AM   #2
Re: Clamp Advice Please?
I highly recommend the Clamp Tripod. I got both the small and large versions. I have trusted the large one with about 6 Lbs. of camera on it, clamped to a balcony railing. I wish the pads were slightly softer rubber, but that's nit-picking. The small version is good for about 2-3 Lbs.
They sell both at the same web-site you linked to.
Mark Watson
Clamp Advice Please?-clamping-tripod.jpg   Clamp Advice Please?-clamp-tripod-xsm.png
Old March 24th, 2014, 08:01 AM   #3
For real strength you really need Manfrotto super clamps rather than any form of crab clamp. They also open wider than crab clamps.:
Super Clamp Without Stud 035 - Super Clamps | Manfrotto
They come with inserts so that they can clamp around round and flat surfaces securely. They have a 1/4" female socket so you can screw in a normal friction arm minus its crab clamp, or you can insert numerous types of studs to which you simply attach a ball head:
Manfrotto MN036-14 Light Stud 5/8M+1/4 S/Clamp - Only £4.00 - Park Cameras Online
If you need a bit more distance between the ball head and the clamp and you don't want to use a friction arm - because of it rotating under its own weight - you can use a Manfrotto rigid extension arm, again with a ball head:
Manfrotto 042 Extension Arm for Super Clamp (042) - Wex Photographic
I think you already know about the incredibly strong and small FLM ball head:
FLM CB18 Ball Head - Ball Socket
These Osrso ball heads got a good write-up as well:
Osrso Inexpensive Mini Ball Heads for Accessories CheesyCam
These Delkin Fat Gecko clamps are secure and open wide:
http://www.amazon.co.uk/Delkin-Gecko.../dp/B003BWD6W8
Pete
Peter Riding is offline   Reply With Quote
Old March 24th, 2014, 09:02 AM   #4
Great advice thanks guys - and very timely as I'm just editing yesterday's wedding and the footage from one of my clamped cameras starts to wobble - looking at the view from another camera I can see someone's 'little darling' fiddling with it!!!!
Yes Peter on your recommendation I bought a few FLM Heads - very well made :)
Pete
Old March 24th, 2014, 09:17 AM   #5
Pete
Yes indeed, no clamp in the world will prevent "little darling" induced wobble.;)
Qualified UAV Pilot with CAA PFAW
Aerial Photo / Aerial Video | Corporate Video Production
Dave Partington is offline   Reply With Quote
Old March 24th, 2014, 09:53 AM   #6
Or indeed bouncy marquee floors - of which I also had yesterday - anyone walked within 10 feet of my light stands and they swayed like masts at sea!
Peter Rush is offline   Reply
