L Bracket anyone at DVinfo.net
Old February 27th, 2014, 05:33 AM   #1
L Bracket anyone
Hi all - for vertical slider shots I'm looking for an L plate that I can attach a 501pl plate to and then my camera (VG20) at a 90 degree angle.
I've seen this from manfrotto but it's a bit pricey - something simpler might suffice
Manfrotto announces the new L BRACKET
Pete
Old February 27th, 2014, 07:41 AM   #2
Re: L Bracket anyone
Those Manfrotto L Plates look really nice. My supplier can get the Q5 for £109.95. I see that Amazon has it for £91.77.
I haven’t seen any alternatives. Especially one with a 501PL which is what I’d want. I do know from my photography days that L Brackets have never been particularly cheap. I’ve paid £150 upwards for a Kirk or Really Right Stuff L Bracket for my DSLRs.
The only way around it would be to get something like the Phetron L-Shae Flash Bracket for Camera (2-iece Set) and add a couple of Manfrotto 577 which would work out just as expensive.
Paul Inglis is offline   Reply With Quote
Old February 27th, 2014, 09:34 AM   #3
All stuff like that seems to be over-priced. Always has been. Its in the same family as extras you have for shooting wide-angle landscape photos in a sequence where you need to keep the nodal point spot on.
If you can live without that particular plate - a big ask I know - then the Manfrotto 322RC2 pistol grip works well on a slider. Its not cheap but it is at least more functional than a simple similar priced L bracket:
http://www.amazon.co.uk/Manfrotto-32.../dp/B000JLK5PK
Its worth fitting an extra adapter to it so that it can be used in all aspects. The 322RA:
Manfrotto 322RA Additional Camera Plate Adapter For: Amazon.co.uk: Camera & Photo
That sort of head is also useful on uneven ground as you can level the cam much quicker and easier than by using a ball head or sliding feet in and out.
Pete
Peter Riding is offline   Reply With Quote
Old February 27th, 2014, 01:55 PM   #4
if you really want to trim the budget...
this
Amazon.com: niceEshop Double L-shaped Bracket Holder Mount for Camera & Speedlite Flash: Camera & Photo
plus one or two of these
Calumet Quick-release Video Head Adapter
should git' er' done
but only because you're using a relatively small and light camera
C100 - GH4 - NYC Shooter
www.DarrenLevine.com
Old February 27th, 2014, 02:49 PM   #5
For the cheapest, easiest solution, find a way to extend the base of any ballhead about 3 inches. Since the ballhead can mount up to 90 degrees and anywhere in between, you can leave it on and shoot horizontal, vertically, or diagonally.
Old February 27th, 2014, 02:52 PM   #6
now there's a good idea.
to add to Warren, if you have a tripod with an extending center column, then you'd be in business
Old February 28th, 2014, 04:29 AM   #7
Thanks guys - I have a 501 head that is mounted on my slider (glidetrack HD) so am looking for something I can attach to that - It needs to be a quick to set up and take down solution.
I have a manfrotto 494RC2 ball head, now If I could find a way of extending it by an inch and attaching to my QR plate I've got a solution!
Old February 28th, 2014, 10:14 AM   #8
i mean, if you literally need just an inch, these things come with a coupler thats about an inch
Amazon.com: Albinar 7" inch Articulating Magic Arm for Mounting LCD Monitor LED Lights Camera: Camera & Photo
Darren Levine is offline   Reply
