Best Shutter Speed for 5D Mark 3? at DVinfo.net
Old February 23rd, 2014, 07:41 PM   #1
I just curious what shutter speed do you guys use for 24f. I normally use 1/50s
Joseph Lau is offline   Reply With Quote
Old February 23rd, 2014, 08:01 PM   #2
Re: Best Shutter Speed for 5D Mark 3?
50 is pretty standard. I don't go below that because of blurring/ghosting. When I go above, I often try to stick with the rule of multiples, even though I have never been taught it matters with shutter speed... so 50, 100, or 200.
At weddings there is rarely a reason I'd want the image to look especially sharp, so if I crank up the shutter, it's usually because it's way too bright - that happens if we're outside during winter up here because of all the snow: f/22 and ISO 100 is still too bright and washed out, so I'll jump to shutter 200.
Old February 24th, 2014, 01:56 AM   #3
Hey Joseph,
I'm in PAL land shooting 25fps, but my shutter usage goes:
-- most of the time, 1/50, to emulate 180-degree film shutter
-- when desperate for more light, and the subject is stationary, might crank down to 1/30, but not during reception dancing (too much motion blur)
-- when faced with flickering lights at reception, will play with shutter speed till flickering is reduced
-- when trying to get shallow depth of field look outdoors, prepared to crank up the shutter speed maybe to 1/400... have found ND filters too fiddly
-- when shooting slow motion, will have shutter speed as high as I can get it, so it's easier for programs like Twixtor to interpolate
-- when filming action type scenes... eg groomsmen playing football in morning, or flowers being thrown over couple emerging from church... will probably crank up shutter, if not shoot slow motion
Adrian Tan is offline   Reply With Quote
Old February 24th, 2014, 04:20 AM   #4
Originally Posted by Adrian Tan View Post
Hey Joseph,
-- when filming action type scenes... eg groomsmen playing football in morning, or flowers being thrown... will probably crank up shutter
This saved me a lot of typing since it's about where I'm at. I'll drop to 1/30 if the speeches are dark but avoid it for anything else. 1/50 for 99% of the time.
Qualified UAV Pilot with CAA PFAW
Aerial Photo / Aerial Video | Corporate Video Production
Dave Partington is offline   Reply With Quote
Old February 24th, 2014, 04:49 PM   #5
On the dslrs you don't need to stick to multiples. Use whatever you like. You had to do it on the likes of the fx1 or xha1 as it would cause weird strobing but not so.
The only time you may need to is with some led light sources.
mintyslippers.com
Danny O'Neill is offline   Reply
