#16 |
Re: Recording speeches audio...
There are plenty of ch69 receivers on ebay - now people are realising time is running out. It seems that these hotels don't have a desire to be within the law!
#17 |
hey Ronan,
I got into the video end of things last year and when selecting equipment for audio i considered many of the problems you've outlined, so eventually i got a Sennheiser ew 100 G3 evolution wireless eng pack, which includes a diversity receiver and a SKM 100 G3 radio microphone. the receiver is mounted on my A cam and the microphone is taped to the event's one either in the church or for speeches at the hotel etc. works a charm, I have full control over the audio. I was caught out a few times when people spoke from different areas of the church and with musicians in the church, the mic being taped to the one the priest was using, I've since solved that I got 2 yamaha c24's, they're great too for those times when something unforeseen arises. I think clear audio is vital for video especially speeches at events like weddings, poor video can be forgiven but if the client cant hear the audio they can become very annoyed!! As far as the Bride & Groom refusing to wear mics etc. i have it in my contract that i will not be held accountable if they fail to agree to cooperate with all reasonable requests that would effect the quality of the finished product. R
http://www.robertcantwell.com |
#18 | |
Can be found cheap. Not a popular mic. But sound is basically the same as NTG3. |
#19 | ||
#20 | |
1. Only problem I see is if the speakers forget to pass the wireless mic along, then the audio will be kinda crappy. 2. This could be really awkward as I'm a one man team, but if it comes to it so be it! |
#21 | |
That said, there really should be some compromise. |
#22 | |
Ch69 is supposed to be used for 4G though, right? Once 4G phones become available, how would they affect the sound system? Would it force the hotels into changing to a new system? |
#23 | |
#24 | |
#25 | |
In your case, what you might be doing is placing a small audio recorder close to the hotel's receiver, and the proximity of the recorder is affecting the system. If so, then, instead of using the internal microphones on your recorder, attach an external mic, and run some cables so that you can relocate your recorder a few metres away. Suggestion might be completely wrong, but that's the first thing that pops into my head anyway... |
#26 |
A bunch of zoom H1s could be a runner. You wouldn't be any chance have an example of how they would sound recording speeches would you?
They are so cheap just buy one and try it out. You'll find multiple uses for it anyway. I've probably shot around 100 weddings using that system now and my wireless stuff is feeling very unloved :- ) They also work well during ceremonies hidden in nearby flowers or attached to nearby fitting with cheap Ebay friction arms etc. That Rode shotgun mic is probably overkill for wedding work. I use a Rode NTG2. Being a proper shotgun mic it has a much narrower pick up pattern than many of the dSLR type mics and so is a great emergency standin to capture unscripted moments that you can't get close to. The NTG2 is preferable to the 1 because it takes an AA battery and so does not need phantom power. The next one up, the 3, is weatherproofed but obviously you don't really need that for weddings. Pete |
#27 |
The drum mic idea Don and Katie mention are excellent solutions, and so are the H1s. I love my H1, for $100 you have syncable audio, it doesn't get any better, for the price!
#28 |
I now use a couple of Yamaha C-24s on the top table which replaced a couple of Zoom H1s. I generally find that I only need to use the audio from one recorder & that the other is just a useful backup. I used to mic up the speakers with a Sennheiser wireless & quickly change over between each speech. That was too fiddly & time-consuming so then I would just have the wireless unit & lav mic in front of the speaker on the table & either get them to pass it along or do it myself. That worked well until they or I forget to move the mic. Now the two recorders are each one third of the way along the table.
I am a big fan of applying quite a lot of compression to the audio in post. That & touch of denoiser & the audio from the little Yamaha C24s is great |
#29 |
For wedding speeches, I'll setup a mic stand with a lav mic (or two, if I have extra time, in which case one is a wireless and the other a hard wired audio recorder) taped to it, then put the DJ's handheld mic on the mic stand. I'll plug into the DJ's board to get that feed too, so then I have the option of which source I'd like to use. I find the DJ's board tends to have some issue pretty often, so perhaps 50% of the time I end up using the lav mic and the rest I use the DJ's feed.
The mic stand is nice since it keeps the speaker from moving, which makes focusing and tracking simple, and also since all of our lights (key, fill, hair light) are setup to be aimed precisely where the mic stand is. |
