Flash induced artifacts at DVinfo.net
Old September 18th, 2012, 05:53 AM   #1
Hi All
As we all have to cope with lots of flashes going off during our shoots - has anyone got an explanation as to why I quite often get (usually when filming in low lights) MPEG artifacts showing the frame before and the frame after the flash - it's not a biggie but I wonder if there is a way around it
Pete
Old September 18th, 2012, 06:22 AM   #2
Re: Flash induced artifacts
Got a notice on this new product that might help Announcing Flash Remover Pro from NewBlueFX
Old September 18th, 2012, 08:09 AM   #3
Hi Pete,
Are you shooting HDV? I see what you describe when shooting dark wedding reception dances in HDV. This is a Long-GOP format, which means only two FULL frames are recorded each second. In the 29.97fps US format, that means a full frame every 15 frames. What about the rest of the frames? They record partial information, meaning the "changes" from the full frames. So the full frames before and after the partial frames are referenced to get more info to complete the picture. I believe when shooting a dark scene with little picture info, the sudden intense lighting, and accompanying detail, are simply more than the codec is capable of handling so it breaks up into lovely blocks unfortunately.
Some folks like to use an outboard recorder like the Atomos Ninja to pull the HDMI feed out of the camera before it gets compressed, and then record that to more robust, high data rate, intra-frame codec like ProRes 422 that would avoid said compression issues.
Jeff Pulera
Safe Harbor
Jeff Pulera is offline   Reply
