Macbook pro core2duo slow for SDE? at DVinfo.net
Old June 24th, 2012, 07:51 PM   #1
I have macbook pro core2duo 2.8ghz, 8gb ram and adobe premiere CS6, I tried editing native DSLR footage, playback is smooth but lags when scrubbing footage, Transcoding 1080p to DV 720x480 24p, 1minute footage took 1:40 minutes to convert. what do you think is the best solution so that I can use this laptop for SDE?
Juan Dela Cruz is offline   Reply With Quote
Old June 30th, 2012, 02:35 AM   #2
Re: Macbook pro core2duo slow for SDE?
Have you run a test with pro res and FCP? It might not be your NLE of choice but it would be playing to your core2duo MBPs strengths. Otherwise I think that hardware has a massive chance of letting you down under the pressure of a SDE.
Stephen Hill is offline   Reply
