Question regarding best output for bluray from 1080 25p
While struggling to figure out which forum to post this in it occured to me to ask the experts in shoot to dvd and bluraybproduction - the wedding pros.
I have a project I shot on an EX1 as 1080 25p. I'm editing in finalcut pro and using pro res 422 on the sequence. I burned a bluray direct fron the program using the share - burn bluray and it kinda looked, well pretty rubbish. The movements were funny and overall there was something wrong with the quality. I exported a quicktime h264 to test on a pc and it looked much better. Does anyone have any tips for how to get the best quality bluray in 25p out of final cut? |
Re: Question regarding best output for bluray from 1080 25p
You can't burn 1080/25p to Blu Ray. 1080/24p, otherwise 720/50p. All to do with being designed for the "NTSC" market while ignoring the far larger "PAL" one.
Ron |
#3 | |
Blu-Ray compliant AVC files.. |
unbelieveable. If I had of known that I would have shot 24p.
Thanks for the link I'll have a read. |
#5 |
Using Cinema Tools to conform to 24p may be your only option. Fortunately Cinema Tools does a pretty good job.
#6 |
Tim I transcode my 25P master to 50i & it looks great, it's a sort of fake 50i. It could be that you transcoded to 24P and thus the weird motion.
#7 |
seems a shame to "waste" the p by transcoding to i.
#8 |
My understanding is that all you need do is create a 108050i disc & that the Blu-ray player then does the right thing. It's effectively 25p inside a 50i wrapper like 25psf when we record on certain cameras. It looks correct on screen when I create the disc with Encore anyway.
#9 |
So Nigel, I have some 25p stuff in FCP X (yes, I know!) in Apple Pro Res 4:2:2. I also have "Toast Titanium".
What do I need to do to "create" what I assume to be a phony 50i movie to encode to Blu-Ray as effectively 25p? Ron |
#10 |
Sorry, I don't know. I am using Adobe Encore & I just add the 25p files from Adobe Premiere & tell it to create a 50i Blu-ray.
#11 |
No, I've never had the problem. I was just suggesting 25P to 24P with Cinema Tools. The conformation is done all the time with PAL video to film. The poor quality of 25P in whatever software the OP was using to burn would be a result of bad conformation. Cinema Tools would do a much better job.
#12 |
Conforming from 25p to 24p with Cinema Tools is effectively what they do with all Hollywood films on PAL DVD. The 4% slowdown is small enough that nobody ever notices but does account for different running times that will be observed with NTSC & PAL DVDs. All Cinema Tools does is flip some bits in the file header to set the frame rate at 24p rather than 25p & is more or less instant. There is no transcoding.
#13 |
No Cinema Tools in FCP X.
Ron |
#14 |
