5D manual audio or not? at DVinfo.net
Old August 12th, 2010, 12:59 AM   #1
Hi guys,
just wondering if you guys use manual audio setting on your 5d when shooting general prep and also for those who are using beachtek/juicedlink, do you use manual or automatic setting?
Thanks in advanced
Santo
If a picture is worth a thousand words, what about motion picture?
website: www.papercranes.com.au | blog: www.weddingvideosydney.net
Susanto Widjaja is offline   Reply With Quote
Old August 12th, 2010, 01:46 AM   #2
I wouldn't use anything but manual the 'pumping' you get with the AGC sounds horrible. The problem is that you have no meters while recording & can only set levels by going down through the menu system. Get familiar with the outputs of the microphones you use & it's not too bad. Only use the internal microphone as a last resort e.g. the batteries just died
Old August 12th, 2010, 06:01 PM   #3
Manual...
But, something to think about....
I notice that when I am shooting in a noisy environment, like around traffic, or where a band is playing, with background crowd noise, that auto setting can keep you from maxing out, and you don't have to worry too much about the camera developing a hiss as sound goes down, because the crowd drone is high enough where you won't have th camera putting a lot of gain in.
Chris J. Barcellos
Old August 12th, 2010, 10:04 PM   #4
I always put it on auto... :(
will try to use manual tomorrow.
I agree on noisy environment like a club party, you would leave it at auto. but probably when you only want to get those voices of people then you would set it to a level where its just peaking when people are screaming but not when they are laughing? if that makes sense.
Thanks guys!
Santo
