Magic Bullet Looks problem at DVinfo.net
Old June 5th, 2010, 12:09 AM   #1
We've been using Magic Bullet Looks for about a year now with PPro CS3 with no problems but recently i noticed that after saving my work and then reopening the file im working on , the magic bullet color and effect i've added is not showing on the preview screen even after i render the whole sequence. it is however showing in the effects control panel..any thoughts on why its not changing the frame? your assistance is greatly appreciated..
Kren
Vertical Video Works | www.verticalvideoworks.com
Kren Barnes is offline   Reply With Quote
Old June 8th, 2010, 01:08 PM   #2
Hi -
I had problems in the past with Looks and CS3, and they were caused by problems with the version of Quicktime on my system. I don't know if tis is your problem, but you could try installing a newer - or older - version of quicktime. With an older version like CS3, I would think old rather than new.
Bill Engeler is offline   Reply With Quote
Old June 8th, 2010, 03:41 PM   #3
Thanks Bill..although im not sure how Quicktime is related to either CS3 or Magic Bullet..does cs3 use quicktime to preview the file sequence?
Regards,
