Importing DVD footage at DVinfo.net
Old January 30th, 2010, 04:07 PM   #1
So I'm trying to capture footage off a DVD for a client.
(No, it's not from a movie. Yes, it's just your typically burned DVD. Yes, the person "owns" the content on the DVD.)
I'm trying to capture it in FCP.
I can see the .VOB file and I can import it into FCP, but with no audio. I did some googling and found "Mac the Ripper", but again same result -- video but no audio when in FCP.
Something I'm doing wrong? Is Mac the Ripper worth anything? Is there a better free program?
I've also heard of buying a cable to plugs into the back of a basic DVD player that plugs into a firewire port or USB port, and change the FCP settings to recognize the player...does that work?
(Note: I don't do a ton of importing DVD footage at this time, so I don't see it economically reasonable to purchase software that I'd only use once or twice a year. But if that's the only solution -- or the cables are the best solution -- then so be it).
Excuse the double posts -- I'm new at this thing.
Jordan Meserole is offline   Reply With Quote
Old January 31st, 2010, 12:27 AM   #2
MPEG Stream Clip is what you are looking for, not Mac the Ripper.
Old January 31st, 2010, 01:52 PM   #3
The audio is not coming in because it's AC3 format. I could tell you a dozen free utilities available for PC, but I don't know what's available for Mac. If I were you, I'd google "AC3 demux software mac".
Chris Davis is offline   Reply With Quote
Old January 31st, 2010, 06:20 PM   #4
I had this problem when I owned a miniDVD camcorder (thank god those days are over with)... MPEG streamclip was the answer after exploring everything else out there (even mac the ripper). I did have to buy a 20$ quicktime plugin if I recall...
steve
Stephen J. Williams is offline   Reply With Quote
Old January 31st, 2010, 06:33 PM   #5
Originally Posted by Stephen J. Williams View Post
II did have to buy a 20$ quicktime plugin if I recall...
steve
If you have FCP, you SHOULD have the MPEG-2 QuickTime component Stephen mentions. FCP/FCS ships with it.
