#16 |
It's actually relatively sensible - if you're there for "backup" and b-roll shots as an "assistant", yes you're "there", but in an entirely different capacity than if you are the primary cameraman/shooter... two different levels of attention, focus, and actual function.
I think the misunderstanding occurred when the guy doing the hiring stated he was hiring for an "assistant" at a low rate, and then expected a cameraman... for the same $$. It's like hiring a guy to paint your trim, and then asking if he'd mind doing the rest of the house since he's there anyway... The problem stems from professional respect, as the OP stated - I don't think he'd have minded whether it was the promised $100, or the appropriate $300, it was being "hired" for one job, then being "expected" to do another so the guy who hired him could "play", and being paid at the lower rate. The feeling of being taken advantage of is no surprise, and if the guy doing the hiring was even slightly thoughtful or cognizant of the OP's feelings, he could have offerred to split the difference when the issue arose IMO. But I somehow don't think the issue will arise again... |
#17 | |
It's a bummer, but you should just move on.
Panasonic HMC150/Canon A1/JVC HD1/Sony Vegas 8.0c |
#18 | |
I understand your gripe, and you have a right to be upset & feel taken advantage of, however as others have said just take the high road & be done with it. You did offer to attend for 3 hours at $100 so it seems you're more upset over being taken advantage of & deceived, than the actual rate you were paid. Bygones. Just learn from it & move on. If they ever contact you again for work just decline and explain this scenario is the reason you will no longer do business with them. Maybe they'll really need your work asap & see this in a different light. (I think someone else asked, was this other "shooter" the boss? If not, can you report his work ethic that night?). Almost sounds like a bad date or ex-girlfriend story, tbh. |
#19 |
Yeah i'm going to leave it be.. not going to worry about it and I'm not working for them any more.
Red Epic available for rent, starting at $500 per day, Scarlets, and Lenses available too. rentals.maddalenamedia.com |
