Quick advice for wedding setup. at DVinfo.net
Old March 24th, 2005, 01:18 PM   #1
Weddin's on April 9th, I was volunteered to video tape a wedding. All I have is the wide angle lens and a DVRigPro. I've done weddings before but this time I wanna go the whole 9 yards.
Thanks.
Newbie using Canon GL2 and Powerbook G4 1.25 gHz 512ram and a Mac Pro
Joe Calalang is offline   Reply With Quote
Old March 24th, 2005, 06:16 PM   #2
Crisp and clear audio is the key. There are many different ways to achieve this, depending on your set up, settings, etc. Something to keep in mind.
Alex B
have you ever wanted something so bad you couldent stop thinking about it? a car, a girl, a skate trick? thats what this video was to me it started as an addiction but turned into an obsession.
-Adam Johnson
Alex Beaupre is offline   Reply With Quote
Old March 24th, 2005, 10:40 PM   #3
If you have enough funds- invest in an iRiver 790 (and lapel mic) and place it on the minister/priest. The investment should be under $150 and will allow you to get audio aquistion of the vows and minister/priest.
Also be weary of using a shoulder mount stabilizer for an entire ceremony. It will be difficult to get tight shots (especially with the fantastic 20x zoom of the GL-2) with perfect stabilization. A tripod is a much better choice.
Glen Elliott is offline   Reply With Quote
Old March 25th, 2005, 06:50 AM   #4
What type of lapel mic should I get? Also, this iRiver 790, it's an MP3 player? I guess it records as well?
Old March 25th, 2005, 07:46 AM   #5
Still Motion
Glenn,
I'm interested to hear your reasoning on placing the iRiver on the priest to recorder the audio fo the vows.
We use a couple iRivers, but to be quiet honest, I'm still a little nervous about only using an iRiver for vows so I often just our wireless system. Even in that case, I have always placed it on the groom, thinking that the priest often talks significantly louder so more distance from the mic would be a good thing to achience a good balance of audio from the thee people.
I would really like to know what you think. As well, for the minister, bride and groom, what is your intended audio setup?
Patrick
Patrick Moreau is offline   Reply With Quote
Old March 25th, 2005, 07:59 AM   #6
iRivers are cool. My 1GB model records over 6.5 hours in 44.384 stereo. I suggest you buy as much memory in it as you can afford, you will want it later. The lapel mic is a good choice for this project, but here is another setup I have been experimenting with. With 6.5 hours. I just turn it on at the beginning of an event, and sync it once in a while to my camera.
The user interface is odd, so buy it with enough time to play with it a bit and probably will have to read the manual as well. I understand it now, but it was one of the harder things I have had to learn how to use (Because I had to read manual).
And whatever you do, make sure you LOCK the iRiver when you set it to recording mode. It shuts off very easily otherwise. Make sure you LOCK it. Make sure you LOCK i t. And besides that, make sure you LOCK it.
Bob Costa is offline   Reply With Quote
Old March 25th, 2005, 08:58 AM   #7
<<<-- Originally posted by Patrick Moreau : Glenn,
Patrick -->>>
Patrick, I use 3 iRivers and a UWP-C1 wireless system. Wireless goes on the groom, iRiver on the priest, iRiver on podium for readers, and another iRiver near soloist and/or harpist.
The lapel mic I've been using is an Azden. Don't know the model # off hand but if you search B&H under Lapel Mics> Azden it's the cheapest one ($15).
Old March 26th, 2005, 10:49 AM   #8
The mic Glen was refering to was the Azden 503...I would recommend it for out events as it has a pretty good windscreen. However, I would recommend the AT830 lapel mic as it has a broder zone of acceptance.....
Here is a clip of the two mics:
http://easylink.playstream.com/foley...ns/mictest.wax
Here is a link to the Azden 503:
http://www.bhphotovideo.com/bnh/cont...u=89741&is=REG
Here is a link to the AT MT830 lav:
http://www.soundprofessionals.com/cg...source=froogle
Mark A. Foley is offline   Reply
