Adding picture's to the timeline at DVinfo.net
Old October 6th, 2004, 03:23 PM   #1
Adding picture`s to the timeline
I am adding picture`s to create a montage for a wedding, some of the picture are small and I want to know when I scan them in using photoshop is there a way to get them to fill the screen ,in a way that they all look even.
Eric Fonseca is offline   Reply With Quote
Old October 6th, 2004, 03:36 PM   #2
Which editor are you using?
George Ellis is offline   Reply With Quote
Old October 6th, 2004, 04:55 PM   #3
This is how I do it, but im self taught
Open file and make a copy. Close the original. Go to image size and put in 720 by 480. Go to the crop tool, and drag it down all the way so it fills both sides. Set it where you want it and crop. Change the aspect ratio to .9. Change to 8-bit. Change to SRGB. Save.
John
John DeLuca is offline   Reply With Quote
Old October 6th, 2004, 04:57 PM   #4
When you import the file in the project bin set the duration before you drop it in the time line.
Old October 6th, 2004, 07:23 PM   #5
I`m using Final Cut Pro. I`ll try doing it the that John
