OH! Boy! Over Exposed....Help! - Page 2 at DVinfo.net
Old August 20th, 2009, 11:11 AM   #16
Tom:
Post a grab of a typical overexposed scene for us to look at and work with. If you have a place to upload a native clip, that would be a great help too.
I would be upfront as possible and correspond with the B&G by email (probably on a honeymoon still) ASAP if this is a big problem. The B&G can help pull friends & family video together for a last ditch effort. Never wait to ask for help, but jump on it immediately. Sure they will be disapointed, but its your job to produce a video no matter what it takes.
As for an explanation, I would just tell the B&G there was a problem with the video camera(s), don't get into details.
Also, if it looked reasonable on the camera LCD, I think it can be made to look reasonably like that in post. If the LCD was just white, that is what you captured. Please post a sample.
Panasonic HMC150/Canon A1/JVC HD1/Sony Vegas 8.0c
Jeff Kellam is offline   Reply With Quote
Old August 20th, 2009, 04:52 PM   #17
Yeah Tom
I Know most user in here a expert maybe they have some trick to help you out. Capture and post the raw footage to megaupload so some of us might have some time and take a look at then post result to help you how to fix. without seeing the footage nothing going to help you best.
Sorry to hear that
Thanh Nguyen is offline   Reply With Quote
Old August 20th, 2009, 05:02 PM   #18
Even just a few stills pulled from the timeline might give some idea of the options. I know some cameras tend to overexpose a bit, but this sounds worse, and once you blow the highs out, there's nothing there - same with overly dark footage, if your footage simply goes out of bounds, it may require some trickery to make it usable... hopefully.
You can't replace data thats outside the normal ranges, BUT sometimes there are ways to salvage - really need to see some sample footage or stills to see what might be doable. don't give up just yet, till we see what you've got, maybe post a couple short clips in the private area if you don't want them public, and let us know here to go look-see!
Lots of potential help here, we've all had those times...
Old August 20th, 2009, 06:13 PM   #19
Originally Posted by Susanto Widjaja View Post
One thing I learned is that always check the LCD screen on your camera if you're renting. The LCD might be set to lowest brightness and you crank the aperture up accordingly.
maybe post a clip for us to judge as well?
I use the exposure meter on my cam ALL THE TIME. If you can't doesn't have an exposure meter, then you probably need a better cam if you are going to attempt this again.
I rented cams for the first 3 years I did this, because I didn't want to sink multiple $K into cams & gear if I sucked at it or couldn't take the pressure. :-)
I ended up thriving on the pressure (extreme wedding adrenalin junkie?) and got decent results. That and I saw a place in the market right below Travis to do great productions.
but back to the OT..... it might help our comments if we saw a frame grab. Otherwise all the "OMG you are screwed!" or "just do the thingamabober wheel and adjust the whosamawatchacallits" are just wild speculation.
Jason Robinson is offline   Reply With Quote
Old August 20th, 2009, 06:14 PM   #20
Wait . . the private area is up now????? How did I miss this?
Old August 20th, 2009, 07:21 PM   #21
if you can't see it you must not have access...
only joking - I can't see anything either
Cheers - Paul M.
www.perbenyik.com
Old August 21st, 2009, 05:31 PM   #22
I'll be filming my second wedding tomorrow, and one thing I always use is the zebra pattern. My camera has a mode to show stripes for 85% and then one for 100%. This way if I see the stripes, I know i have a little lattitude before it blows out. In my limited experience, I tend to underexpose. I gotta get better at that.
Good luck recovering what you can. Like someone else mentioned here, things look great on the LCD, but that's not indicative of the final product.
Eric Pasarin is offline   Reply With Quote
Old September 1st, 2009, 10:08 PM   #23
Sorry Dude... sounds like a mess. I also shot a small party and it was overexposed, but I was able to cover with some clever editing. Lucky I only charged a few bucks and was able to cover.
I'm actually shooting my first wedding with my PANNY HMC150 (non-paid for a friend - thank god) and am looking for some general down and dirty scene file and camera settings for the HMC150 that will get me through the day. These are very good friends and I don't want to mess it up.
I am going to need some outdoor settings suggestions for daytime, Church settings and some nighttime settings for indoors at for the hall with some of windows that will let in light. Some general indoor settings for bridal shop/ bridal prep and house etc would be great also. I'm knee deep in terminology so till I ramp up I was looking for a little help.
Someone please help me ( and Us) through this world of GAMMAs Knees and other stuff? Also suggestions for best shutter in these environments would be welcomed. I'm thinking I will shoot in 720P @ 60P because 1080/60i seems to be hard to work with in FCP. Thoughts?
Thanks in advance all !
Cheers,
Steve Berg is offline   Reply With Quote
Old September 1st, 2009, 10:16 PM   #24
Also willing to help dude. I had the same problem and with a little time shifting and filters and VO work you might be okay! There might be a better way to tell the story by not using all your footage.
Old September 1st, 2009, 10:58 PM   #25
Cheers,
Steve,
Personally I wouldn't shoot presets at a wedding - once they're on, you can't get them off. I used to shoot presets on my XLH1 a lot but stopped and used cc later if needed. I don't know your 150 at all, but we used to think the stock colors on the H1 were pretty flat - which they are - but they're easily tweaked in post. So... unless you have a lot of experience with a preset - I would advise to shoot stock settings and cc in post. Then just make sure that you're properly white-balanced for each changing setting, that you're properly exposed for each setting, and that you're getting clean audio.
For weddings, especially in the beginning - it's WAAYYY better to play safe and risk being a little boring than take risks and have it blow up on you.
C100, 5DMk2, FCPX
Old September 2nd, 2009, 12:55 AM   #26
I stand alongside Ken on this one. Get the exposure correct and locked, get the framing right, shoot clean, unadulterated interlaced video if you're starting out fresh. Next, it you've got the time, lock in the correct white balance and use manual focus. Lastly (with your third hand and third eye) use manual audio levels. That is, leave the audio limiter on and concentrate on all those other things.
In post you can muck about as much as you like, and most importantly click the 'undo' tab.
tom.
Old September 2nd, 2009, 04:42 AM   #27
count me in with Ken and Tom on this one. Shoot simple clean steady footage that is BORING! They'll love it. Once you get familiar and used to the camera you can try different settings, different things, but NEVER practice on the job.
BTW, you're issued the 3rd hand and eye after about 10 to 15 weddings. After a couple hundred you get a 4th hand and after the first 1000 you get the 4th eye and 3rd ear.
People may look at me funny but the worst is finding shirts with 4 sleeves!
Don
Old September 2nd, 2009, 02:40 PM   #28
Thanks guys,
Tom I noticed that you said shoot “pure interlaced video.” Can you explain? I shot with 1080i/60i on the HMC150 the other day for a small event and it was a nightmare for FCP to handle. I had to convert all the footage to progressive and it took like 10 hours or more to render and then it needs to render each time you make a new cut or apply a filter. Yikes! I was thinking of shooting 720P/60P at least 60 to 100+ FPS.
So, net, net it seems to be keep it simple. I agree. Just wanted to find some best practices for securing the best images possible. I have to keep it on at least one setting ---any recos on which one to use. Also for the HMC150 there is a setting called DSR seems to really help with keeping the whites and blacks in check for situations where there is no light consistency helping to avoid over exposure.
Apologies if I hijacked the thread… but I think this info is very helpfully for all of us novices. And certainly helps us develop our 3rd and 4th hands.
Thanks again,
Old September 2nd, 2009, 05:56 PM   #29
Thanks guys,
Thanks again,
Hmmm... I think (quote: 'think') Tom may suggest interlaced mean because the video will ultimately be shown on a TV via DVD. Have you followed your existing workflow thru to rendering and burning to dvd?
Because we all use different cameras, the 'best all around' setting is going to be different for each camera. This is where you probably should ask others who use it. Generally I just use the out of the box setting for all my cams. Another good thing to do is to calibrate your LCD viewfinder for brightness at least - you don't have to get all techy, just shoot different footage in different light and see if it looks the same when played back on a monitor. Oh, and for sure... don't expect your on-board mic to pick up anything useable at all, most likely just someone near the camera making inappropriate comments.
One of the best ways to play it safe is to have an extra cam on a tripod. The last 2 weddings I shot, I ran 3-cameras solo, (just for the ceremony) but I wouldn't recommend that. If you shoot only one-camera, shoot lots of b-roll for cutting in later. I used to always shoot one cam and would try to get neutral crowd shots just before the ceremony started, just to use for cut-aways when someone invariably stood up in front of the camera, or or something similar. In this case you want to continue to record audio - quickly adjust your position, and keep going.
Re: 'best images possible' = the images of the couple, their families and the special parts of the day - well composed and exposed. Does not equal - the back of someone elses head or similar (even if it is in focus and well exposed).
Herein lies the problem. Many people think that they will start out on weddings, that they are easy... To shoot them properly, Weddings are one of the toughest challenges a shooter can face. I've shot lots of stuff in nearly 20 years, and weddings are far and away harder than most things. Largely, this is because of the pressure, and we have so little control over things.
I was shooting a promo piece for a realtor a couple of months ago and he had flicked on the mute button while fiddling with the wireless transmitter in his pocket. No problem... yell "cut", find the problem (I had to sweat for a few minutes while I figured it out) and re-take. Most jobs are like that, and if worst comes to worst - reschedule and reshoot. Not possible at a Wedding.
BTW, Hahaha, good one Don! 4 sleeves...
C100, 5DMk2, FCPX
Old September 2nd, 2009, 11:54 PM   #30
If you're shooting 60i your camera is capturing everything that happens in front of it. You can de-interlace this footage later should you wish, but progressive footage is generally more 'stuttery' looking on the pans and with subject movement - the film look, if you like.
But your description of FCP's reaction to this makes me think twice about the recommendation in your case. The whole point about SD card capture being a quick file transfer process is negated somewhat. So it's good what you're doing - shooting and checking and shooting some more.
tom.
