Video Size Help Please at DVinfo.net
Old April 20th, 2009, 07:07 PM   #1
Ok, I shoot with the XH-A1 in HD and want to make sure I am doing a few things right, and if not change them now before I have a lot of video sized wrong.
I use Premier Pro CS3 and Cineform Prospect HD.
When I import video I have been using the setting.
"Video Frame Size: 1440x1080
Frame Rate: 29.97 fps (59.94 fields interlaced)
Display Aspect Ratio: 16:9
Pixel Aspect Ratio: 1.33:1
Audio: Stereo 48kHz (16 bit)
Drop-Frame Timecode numbering."
Is this what I should be using when shooting 60i, I also crop photos 1440X1080 so they fill the frame when I use them.
I have not had any luck trying to decide exactly what size video I should start with, my end products are posted on vimeo, and burned to DVD for customers.
If I am doing something wrong, or different than you would do, would appreciate the tip, and what you would suggest.
2 Canon XF305's
Kyser Photography www.kyserphoto.com
Denny Kyser is offline   Reply With Quote
Old April 20th, 2009, 07:22 PM   #2
Hey Denny,
At a glance everything looks good. If your system can handle it, you're better off editing in HDV and then down converting on export. One quick plus is that it gives you freedom for reframing shots if necessary.
One thing you mentioned that I'd watch out for is cropping your stills to 1440x1080. There's no problem in doing that itself, but when you import them, Premiere will most likely 'intuitively' interpret them as having the HDV aspect ratio. That's probably why the stills in the video you posted looked stretched.
You have to override this by forcing Premiere to interpret them as square pixels. I don't use CS3 but it should be pretty simple: before you drag the image to the timeline, right click on it in the project window and in 'Interpret footage' select square pixels or 1:1 ratio or something like that.
Hope that helps,
Matt.
Matt Barwick is offline   Reply With Quote
Old April 20th, 2009, 10:31 PM   #3
Thanks Matt, makes sense.
Would I be better of using one of these two settings.
Video Frame Size: 1920x1080
Pixel Aspect Ratio: 1.0
Or.
For editing with HDV equipment.
Video Frame Size: 1280x720
Frame Rate: 29.97 fps (progressive)
Non-Drop-Frame Timecode numbering.
Making the Pixel Aspect Ratio 1.0, Sorry such a newbie questions, but this part is confusing to me.
2 Canon XF305's
Old April 20th, 2009, 10:39 PM   #4
Ok, Matt you were right, making them a 1.0 square pixel "un stretched them" but now they do not fill the screen, I cropped them the same resolution as the video 1440X1080 I do not understand why its not the same???
2 Canon XF305's
Old April 20th, 2009, 10:54 PM   #5
Your video displays a 1920 x 1080 frame size because HDV pixels are elongated at 1.33.
Your photos, if they have a square pixel, should be a 1920 x 1080 to match the frame size fo the HDV material.
Chris J. Barcellos
Old April 20th, 2009, 11:03 PM   #6
Yep Denny - what Chris said.
I didn't point out that you shouldn't be cropping your images to 1440x1080 if you want them to fill the screen, which is displayed at 1920x1080.
Crop them to 1920x1080 and premiere will (or at least should?) interpret them as square pixels or 1:1 ratio and they'll fill the display.
This thread should probably be in the Premiere section BTW.
Old April 20th, 2009, 11:40 PM   #7
Sorry for putting the post here, was not sure if the resolution and size would be different depending on what type of video you are shooting. I guess HD is HD regardless of what the subject is.
2 Canon XF305's
