quickbase for fig rig.... at DVinfo.net
Old January 25th, 2009, 03:48 PM   #1
I know that there are a few people out there using this for weddings/projects.. I'm interested in buying a fig rig but I dont think it would be practical for me unless I had a quickbase to go with it. I'm hoping to be able to leave the quickbase attached to my tripod and when needed to go handheld, I can just go....
I cant find the quickbase for sell anywhere anymore. It's a discontinued product by B&H... any ideas???
Stephen J. Williams is offline   Reply With Quote
Old January 26th, 2009, 05:09 AM   #2
Do a search on Manfrotto/Bogen 577. It's using the same plates as a 501/503 head.
Hubert Duijzer is offline   Reply With Quote
Old January 26th, 2009, 12:07 PM   #3
I think your talking about the quick release plate... I need the wire frame that attaches to the tripod and the fig rig slides into... The company that used to make it only has one more left. Just curious if any of the fig rig users on this board happened to have one that they dont use often.
Old January 26th, 2009, 01:40 PM   #4
You're right. Sorry. I've never heard of a quickbase before.
After re-reading i now understand what you meant.
Old January 26th, 2009, 02:22 PM   #5
I don't like mounting the figrig to my tripod - way too jumpy. I use a bogen head on my tripod, so I take the camera off and put it on the tripod. It's a trick and I'm always leaving my figrig everywhere, but I feel like it's worth it for the extra stability.
Philip Gioja is offline   Reply With Quote
Old January 26th, 2009, 02:32 PM   #6
I also use a bogen tripod and head. But the plate that fits in the fig rig wont fit in my head... I rather not have to buy a new head just for connivence. I though the quickbase would be a good solution since I could leave everything mounted. Then grab and go for those mobile shots. I waste so much time now just rushing to set up between handheld shots and steady shots with the tripod. I figured this would be a good way to get around it.
are you saying it's way to jumpy while using the quickbase?? If you dont like using maybe I can take it of your hands for you.......
Steve
Old January 26th, 2009, 03:06 PM   #7
Steve
I hang my figrig on a c-stand when I'm not using it. Works great. and dead simple. Cheap too.
Old January 16th, 2010, 07:27 PM   #8
Seems like a common problem with the Fig Rig setup... cant put it down and hard to mount it on anything. There are alternatives.
Jon Kon is offline   Reply With Quote
Old January 16th, 2010, 10:47 PM   #9
Stephen, I wouldn't worry about being unable to find the quick stand for two reasons.
Firstly is aesthetic - it's a big lump to have, especially at a wedding where most of us try to fit in discreetly.
Secondly, and more important, assuming you'll be using a demand arm on your tripod, and assuming you'll have one of Manfrotto's cut-down versions on your Fig Rig, you're going to have to unplug the camera as you set it on the tripod anyway.
Our solution is to have the same 501 quick release plate on the Fig Rig and the tripod. As I'm walking from the end of recording the bride arriving at the church, I detach the Lanc control and the camera from the Fig Rig. By the time I reach the tripod position, just upstage from where the couple will stand, all I have to do is to slip the camera on to the tripod and bang in the Lanc lead from the demand arm.
Incidentally since all the cameras will be running in sync for multi-camming in post, we don't stop the camera during the detachment/re-attachment process.
Philip Howells is offline   Reply With Quote
Old January 17th, 2010, 04:38 AM   #10
I use the 502 quick release plate with my Fig Rig too. Works fine.
http://www.gooderick.com
Richard Gooderick is offline   Reply
