Fig rig's - Page 2 at DVinfo.net
Old January 17th, 2009, 08:11 AM   #16
the trick is not to go too low when cutting.
I went right down to almost 9 o clock and 3 o clock..
If you stay high enough so your hands are at the same or slightly above the
camera when attached. Otherwise the balance gets a little affected.
Cutting the bottom portion off works great as its easier to hold the rig
by that vertical type screw in thingy, if needs be.
Ger Griffin is offline   Reply
