How much footage on 1 DVD? at DVinfo.net
Old August 29th, 2008, 12:58 PM   #1
The wedding I am editing now is at 1 hour 46 minutes. Before I render all this, will this fit on a single DVD and have good quality?
Not sure what the longest is you can put on a single layer DVD and still keep the quality good.
2 Canon XF305's
Kyser Photography www.kyserphoto.com
Denny Kyser is offline   Reply With Quote
Old August 29th, 2008, 01:59 PM   #2
DVD's are 2 hours so yes an hour 46 will fit just fine :)
Louis Maddalena is offline   Reply With Quote
Old August 29th, 2008, 02:38 PM   #3
The amount of 'footage' you can put on a SL DVD basically depends on the bitrate that you use. you can use a bitrate calculator to figure what you need to use but up to 2 hours usually looks pretty good. If you use too high a bit rate you can cause confusion with some DVD players.
Puttin the wet stuff on the red stuff!
Terry Esslinger is offline   Reply With Quote
Old August 29th, 2008, 02:54 PM   #4
Hi,
And just to add to the confusion, the better encoding software you use, the more you can add (and still make it look good).
A good calculator is located at Bitrate Calculator. Hope this helps.
My best.
Mike
Mike Gunter
VideoTidbits.com
Mike Gunter is offline   Reply With Quote
Old August 29th, 2008, 06:18 PM   #5
Hey Denny,
What software are you using?
jones
Chris P. Jones is offline   Reply With Quote
Old August 29th, 2008, 09:29 PM   #6
Originally Posted by Chris P. Jones View Post
Hey Denny,
jones
Adobe Premier Pro CS3, to Encore.
2 Canon XF305's
Old August 29th, 2008, 11:28 PM   #7
if you want high quality make sure you don't go above 1: 30 per dvd. Unless you have a nice encoder.
Kiflom Bahta is offline   Reply
