How do you prevent clothing static... at DVinfo.net
Old August 15th, 2008, 08:35 AM   #1
...with wireless mics? I often use my iriver 895 w/ giant squid mic on the groom for wedding productions. There are times when I get the annoying clothing static. Is there anyone out
there that has been able to conquer this problem? I'm thinking about wrapping the mic in black silk cloth, but not sure if this will do it. I guess it's worth a test.
Troy
Troy Davis is offline   Reply With Quote
Old August 15th, 2008, 09:27 AM   #2
I'm not sure about your specific mic and how you position it on the groom but here's what I do to avoid that as much as possible.
I put the mic higher on the groom's tux..usually above the flower. This keep it away from the center where there's much more potential for rubbing and hitting it with his arm and such. I also loop the wire right off of the mic. This will help a ton to remove any noise from the loop down. Then if he's moving around, the only noise you'll get will be if he actually hits the mic....which again, is very hard when it up close to his shoulder.
If you're unfamiliar with looping the wire, watch any newscast and you'll see it done on the anchors.
These two things have dramatically reduced excess noise for me.
Matt
Matt Bishop is offline   Reply With Quote
Old August 15th, 2008, 09:41 AM   #3
Thanks Matt. That helps. I will be trying out my new Olympus DS-30 this weekend, so we will see how this works. I will see what I can find on looping the mic wire.
Old August 15th, 2008, 12:01 PM   #4
The squid mics are great but the clip is just too close to the capsule. It helps to use a shorter lav cord (a 2 footer) as it won't bunch up in the grooms pocket and work its way out wiggling the mic itself.
The mics that come with the Sennheiser G2's have that wire loop and I never have a problem with them brushing up against clothing.
Rick Steele is offline   Reply With Quote
Old August 15th, 2008, 02:41 PM   #5
loop
Looping? <10 letters>
mintyslippers.com
Danny O'Neill is offline   Reply With Quote
Old August 15th, 2008, 03:25 PM   #6
go to any office supply store. Get a few vampire type paper clips. They are sprung and have a cutout in them to hold thicker tings and also have 2 pins to pin to clothing. Hence, vampire clips.
After installing the mic on the groom take a small amount of wire and run it back up to the mic clip. Clip it so there is about a 1 inch 'loop'.Now take the rest of the wire and wrap it into about a 3 inch loop, take your new vampire clip clip it all together and pin it to the inside of the grooms jacket.
It will not do any damage to the jacket or wire as long as you are careful with looping the wire and clipping it to the lapel clip. I've done it for years and never damaged a wire.
The better solution is to get a mic clip with a wire clip on the back side so you can run the wire up thru that before wrapping it and clipping it to the jacket. they are very inexpensive and can help keep the wire seperated from the subject.
AAMOF I use vampire clips on my mics (came with the Countryman mics). No big clip looking ugly on the jacket plus with the clips from the office store it makes micing the subject up as easy as chocolate pie;-)
Don
Old August 15th, 2008, 06:38 PM   #7
Use a newsman's loop on the cable. Instructions here:
About Lavalier Mics
Nothing to buy, just a cable-rigging operation.
Martin
Canon XF300, Canon 5DMkII, Canon XL2, Rolls MX422 mixer, Zoom H4N, AT899 lavs, AT2020's, Azden SGM 1X shotgun, Manfrotto 501 head on 351 tripod
Martin Catt is offline   Reply With Quote
Old August 15th, 2008, 08:09 PM   #8
yep, that's what I was trying to explain. The thing is, my mic cables are 48" long (standard length on the EMWs) so there's a lot of extra wire hangin' around. that why I suggested the "paper clips" not as a loop but as a way to get the extra wire out of harms way.
BTW, thanks for the link. I've been trying to remember what it was to give to people.
Don
Old August 18th, 2008, 08:02 AM   #9
About Lavalier Mics
Martin
Thanks Martin,
I was looking for instructions for the loop.
Troy
Old August 18th, 2008, 09:16 AM   #10
Silk
Troy in your original post you mentioned wrapping the mic in silk. I don't think that would be any good: I've found that the worst ties for producing noise are silk ones - maybe static electricity is being generated somewhere. Persuade the wearer to change to a cloth one and things improve at once (admittedly awkward if the tie is a marker of prestige, such as MCC, Guards, Institute of Confused Sound Recordists).
However, wrapping the mic in a Rycote Furry works well, even under clothing.
Nick Flowers is offline   Reply With Quote
Old August 18th, 2008, 11:30 AM   #11
Thanks Nick. I went w/o wrapping the mic and the proper placement on the lapel seemed to work well.
