Where do you wedding guys..........? at DVinfo.net
Old July 9th, 2008, 03:53 PM   #1
Where do you wedding guys set the sensativity and af out on your Senheisers. I just got the ew100 g2, 00 seems a little too hot as does the -10, but -20 seems not hot enough on the sensativity, so Im thinking -10, and on the AF out Im thinking -12? This is on the grooms mic...Thanks!!!
Shaun Steele is offline   Reply With Quote
Old July 9th, 2008, 04:22 PM   #2
Hey Shaun,
I go -10 on the mic and -18 on the AF...
I'm watching television... in color
http://www.prodigyvideo.com
Nathan Nazeck is offline   Reply With Quote
Old July 10th, 2008, 03:44 AM   #3
<< I go -10 on the mic and -18 on the AF >>
Shaun,
I use the same settings as Nate. By clipping the mic low on the groom's lapel -- just above where he buttons the coat -- I get almost equal levels from his voice and the bride's voice. Saves a little time with tweaking later on. Good luck.
Bill
Bill Anciaux is offline   Reply With Quote
Old July 10th, 2008, 06:11 AM   #4
I use -20 on the mic and -6 to -18 on the receiver depending on the situation.
Jon Omiatek is offline   Reply With Quote
Old July 10th, 2008, 07:45 AM   #5
There is a video tutorial on the Sennheiser G2 that will help you set it up correctly at the link below.
http://www.dvestore.com/theatre/#
John J. Moon
www.northernlightfilmworks.com - Event DV Top 25 Recipient
John Moon is offline   Reply With Quote
Old July 11th, 2008, 01:01 AM   #6
Thanks!!
Thanks for the help guys, and also the tutorial...............Shaun
