One Tight SDE - Page 4 at DVinfo.net
Old May 22nd, 2008, 09:13 AM   #46
Your work is truely inspirational. Deffinatly differnent to what we get here in the UK. Were much more traditional (static, slow mo, B+W etc).
Danny O'Neill is offline   Reply With Quote
Old May 27th, 2008, 05:41 AM   #47
Matt & Simon,
I think Patrick only uses Canon cam at the moment. A1 and H1.
Kenny Shem is offline   Reply With Quote
Old May 27th, 2008, 05:47 AM   #48
Patrick,
may I know whenever you shoot those silhouette scene, what settings did you do the cam? They look good. I'm using Canon XH-A1 too. You bump up the contrast level in post too right? :)
Old May 27th, 2008, 05:49 AM   #49
I would say close the iris or maybe the spotlight button (if it has one) could also yeild the same effect.
Old May 27th, 2008, 05:51 AM   #50
I tried that and had the f-stop bump up, but that makes the image v dark, including the window. Is there any special technique to achieve it?
Old June 10th, 2008, 06:21 AM   #51
Simply amazing work. I learn something new every single time. Patrick, what system are you using (macbook pro, desktop) to capture and edit your SDE's? Also, do you present your SDE's in HD? In a tight edit like this are you playing from the laptop, DVD player, or through something like a Matrox MXO? Thanks for continually inspiring us all to do greater work!
Joel Campos
studio red www.studioredweddingcinema.com
Joel Campos is offline   Reply With Quote
Old June 10th, 2008, 08:51 AM   #52
Here you go Joel!
http://stillmotionblog.com/?page_id=153
dreaming hobbyist + storyteller
www.michaelywong.com
Michael Y Wong is offline   Reply
