How do you guys handle a live video feed request? - Page 2 at DVinfo.net
Old October 1st, 2008, 12:08 PM   #16
Hi Jason,
Yup that would be a roving camera, normally he gets the brunt of the shoot as he/she has to hand carry and be very mobile. The mini-dv decks would be stand alone recorders, 2nd deck would start recording when there's a minute left (tape wise) in deck 1. For back-ups each Camera can do an Independent record as well.
I have no experience recording straight to PC at all.
Noel Lising is offline   Reply With Quote
Old October 1st, 2008, 01:38 PM   #17
Originally Posted by Noel Lising View Post
Hi Jason,
I tried it a few weeks ago. Worked pretty well, though was major hassle to tear down the office, setup on location, tear down at location, and re-setup back in the office.
Jason Robinson is offline   Reply With Quote
Old October 1st, 2008, 01:39 PM   #18
Hi Jason,
I also assume you have some device that transmits the eng cameras signal to the switcher. Care to share what it is?
Old October 1st, 2008, 01:55 PM   #19
Hi Jason,
All cameras are wired.
I read your post about recording directly to PC, it's good you recorded to tape as well.
Old October 1st, 2008, 02:06 PM   #20
Hi Jason,
Backups. I'm all about backups.
So how does a roaming camera op on a steadicam get their feed back to the mixer via a wired connection with out that completely screwing with the balance of the system? Or was the roaming op not part of the live mix?
Old October 1st, 2008, 02:31 PM   #21
Hey Jason,
I was thinking of the ENG guy shooting without a stabilizer, shooting using a shoulder mounted camera. Adding a stabilizer to the mix would be a challenge, you have to run down the cable along the stabilizer ( 2 cables if you're using component, one for the clearcom and one for the camera), you also need a wrangler for the cable. It would be a PAIN.
Old October 1st, 2008, 04:39 PM   #22
Hey Jason,
Ok a shoulder mounted system made more sense. I recently ran across a coax broadcaster to send the video + audio signal to a receiver. Very interesting. The price was only $100 or so, and would substantially pump up the mobility & utility of a live broadcast.
