#1 | |||
Re: Indian Wedding
Hi Note
I don't think I would have shot straight into the bright light on the outdoor shots at all. That sky is mighty bright so going around the other side of the wall probably would have been a better idea. I always tell my assistants to keep their backs to the sun/bright backgrounds/windows ...now and again a sun flare can be nice as a special effect but it's tough to expose correctly when trying to shoot into a heavy backlit situation and even gamma correction won't really help. Was this on a DSLR or a small video camera?? From the shallow focus I would say a DSLR and you also need some sort of rig/stability control to iron out the wobbles on the outdoor footage ... even a monopod would be good there rather than handheld. The indoor shoots looked pretty good to me except for one or two lost focus bits. I know a shallow DOF always looks impressive but sometimes it's worth stopping down just a bit (or getting in closer and using a wider lens) so you have enough DOF to cover the couple when they are moving. Rack focus with a tiny DOF isn't easy to achieve consistently. I'm sure the couple will love their video Chris |
#3 | |
Re: Indian Wedding
It was shot on a bmc. It was on a tripod with very bad dolley legs hence the wobbles. Next time I will not use them. Which outdoor shot do you mean? I did not include any outdoor shots, rather the one in the forest the couple's friend shot and a year ago and recently gave that to me. And I agree about the DoF, it is annoying when its not in focus. I hope that the other cams did get good shots (f you underexpose on this cam then this introduces a line straight down the sensor.) |
Re: Indian Wedding
Hi Note
Yes I meant the little stone gazebo in the forest. It certainly didn't look like the indoor footage either.. if that was from another person then there is little you can do about it especially the wobbles and exposure but the content is still precious to them so you still need to include it ..maybe just mention to them that the beginning footage was from a third party? The BMC produces an amazing image indeed!!! Chris |
#5 | |
Re: Indian Wedding
I'll have to go ask the couple who shot that footage. When I spoke to the bride at a sit down session that was supposed to last 30 minutes, she spoke for over 40 minutes about that hilltop. I do wish I was there, and more so in Australia! |
#6 | |
Re: Indian Wedding
One suggestion in this thread is that you should output as wmv instead of h.264. Another is to colour grade differently for Vimeo: https://vimeo.com/forums/topic:46866 By the way, I'm seeing noticeable chromatic aberration on a lot of your footage. Don't know whether it's the lens or the camera. |
#7 | |
Re: Indian Wedding
It's the lens. It's a rokinon 85mm 1.4 (used this lens the whole day) which I bought for $225. |
#8 |
Re: Indian Wedding
Well h.264 in itself darkens the shadow area. Or so I've always been told (never tested it myself).
One theory of how the Cinestyle picture profile works on DSLRs -- it raises the black point up to around 8 (?IRE) to avoid h.264 crushing the detail out of the shadows. |
#9 | |
Re: Indian Wedding
i know if i export from premiere as mpg i don't get the shift. I've tried a lot of fixes and none have worked and so for the last few months I just exported using my macbook |
