#1 | |||
Re: My first 'big' non-wedding job
Hi Clive,
Great work, im sure your clients were more than happy with it. The sound honestly wasn't as bad as you think, it definitely could be better though and a Zoom H1 with a decent lav mic will help out there. My only recommendations would be to try and get more cut-away's for the interviews and try to spice up shots during the interview with the two talents, EG: shots of hands, the river running behind them, tree's blowing in the wind, reaction shots from the interviewer. Did you use 1 cam? Either way some interesting footage and beautiful Irish country! |
Good work. More b-roll will enhance the film. When using cutaways during interviews I do usually use more cutaways clips together. Insted of using one clip and then cut back on the speaker (Noel in this case) try using several cutawayclips.
The audio was ok. There was a bit of a room tone in the dubbed audio, if you do not have a "dead" room to record the dubbed audio try do it outside or in the same setting as the film is taking place.
http://akfilm.is |
