Cheap HD field monitor? - Page 2 at DVinfo.net
Old June 15th, 2007, 11:13 AM   #16
http://lcdracks.com/monitors/vr70phda.html
Canon XHA1, SGpro,Flip,FF, RR Mattebox, Nebtek V-R70p-HDA with Canon, Nikkor Primes 24mm f2.8, 28mm f2.8, 35mm f2.0, 50mm f1.4, 85mm f1.4, 105mm f1.8, 135mm f2.0, and 300mm f4.0.
Cary Lee is offline   Reply With Quote
Old June 15th, 2007, 11:48 AM   #17
Originally Posted by Cary Lee View Post
The monitor you are linking to is not HD. Resolution is only 800x480.
Chapter one, line one. The BH.
Mike Teutsch is offline   Reply With Quote
Old June 15th, 2007, 11:59 AM   #18
Of course it will not be up to 1080i in that price range. If you want to spend 3x that amount..they are available..but in reality most people don't want to spend more on a monitor than their camera. This monitor has blue only, Component, and 16:9/4:3. But for clarity and bang for you buck this monitor has it...until Nebtek comes out with their new one this month. PS I've seen the Ikan v8000HD monitor... a softer image and found it to be too hard to get a good focus vs the Nebtek. Especially when using a 35mm adaptor and you can physically flip the monitor. In addition i found that with the correct color bar calibration, the footage seen on this monitor is depicted closer than what is on the LCD of the Canon. Very important aspect because you can catch yourself from under lighting the scene and causing viewable grain in the output, even when the gain is set at -3db. Most important thing when using a adaptor, lighting, framing and critical focusing on your subject.
