cheap, small component distribution amp at DVinfo.net
Old April 3rd, 2007, 12:37 PM   #1
We needed a little portable component splitter/distribution amp for using with our little 8" SWIT and 17" LCD (for immediate verification monitoring) when we do crane/tripod work in the field. We'll use the component dongles off our Sony's into the D/A, then take one to the SWIT (no component pass thru...) and other to big LCD in our video/audio cart. Reviews are instant and easy this way! Especially with the V1U.
It had to be small, tough, 8~18 DCV and only needed two component outputs. I think we found a good USA source for only US$59.95 here:
http://www.inday.com/hdda2/hdda2.htm
Here's their specs on this little guy:
  • HDTV Analog Distribution Amplifier (DA). RGB/YPbPr (3-channel) Distribution Amplifier.
    Spit any component video signal without degradation.
    Each output has its own High-Current Cable Driver.
    High current output IC's drive very long cables (> 300') easily. No interaction with other outputs.
    Will accept any analog input, Composite Video, Y/Pb/Pr or R/G/B at any scan rate and give you 2 identical High Bandwidth (200MHz) outputs.
    All Connectors are Gold Plated RCA.
    Great for Automotive video applications. Wide DC power supply range (8-18 VDC).
    Use as SPDIF/AES-EBU (Digital Audio) DA to split PCM, DTS or AC3 Digital Audio.
    Power Supply (12VDC) Included. Actually MADE IN THE USA!!!
    Perfect as a Broadcast Utility DA at a fraction of the cost.
Any negative opinions or comments? We should know if it makes it thru the mail to Brazil...
http://lightinaction.org
"All in the view of the LION"
Stephen Armour is offline   Reply
