16x9 camera monitor for HVX200 at DVinfo.net
Old May 16th, 2006, 10:16 AM   #1
What would be a good 16x9 camera monitor for the HVX to attach to the hot shoe or the horizontal bar of the fig rig.
Can it be battery powered? Also I suppose I would use the HVC component out to component in on the monitor.
Richard Lescallette is offline   Reply With Quote
Old May 16th, 2006, 03:46 PM   #2
Marshall .....
The Marshall SD/HD 7" monitor is the one that affordable and works quite well.
Dean Harrington is offline   Reply With Quote
Old May 17th, 2006, 08:43 PM   #3
Take a look at www.nebtek.com. Monitors, including Marshall, adapted for use with your camera batteries. Also, added brackets and connetions for more durability.
David Trenkle is offline   Reply With Quote
Old May 19th, 2006, 08:11 AM   #4
Go Go Godzilla
Images: 15
Body Mechanics
Hi Richard,
Although it can be done the Fig Rig and other handheld stabilizers weren't designed to add that much on-board weight. It's not that the unit won't handle it, it's that you'll be over-stressing your wrists, forearms and elbows holding up all that equipment.
Unless you have a lot of upper-body strength, and I don't mean being naturally strong, but having real muscle stamina which can only come from resistance training or classic weight lifting you'll fatigue your arms and even shoulder muscles in less than 10 minutes holding up the HVX, monitor, batteries etc.
If you want to test your own strength/stamina take a 10-15 pound dumbell and hold it in both hands out in front of you as if it were the Fig Rig. See how long you can just HOLD it in position before you have to lower it. The results may surprise you.
Old May 20th, 2006, 11:19 AM   #5
Thanks for the advise. I think that makes good sense. I am going to try it all together to see how the weight is before attempting the monitor.
Old May 25th, 2006, 10:16 AM   #6
The Nebtek's look interesting ,
But I am concerned about a High Def image. I use a 35mm adapter and focus is critical.
The Nebtek doesn't say HD - and I can't view them at a store , like say, B&H...
Any experiencewith these?
John Benton is offline   Reply With Quote
Old May 25th, 2006, 01:59 PM   #7
John,
They do have HD. Try this link for their HD monitors.
http://www.nebtek.com/products.php?cat=27
Otherwise click on Products/Sales; LCD Monitors; Marshall.
They're product is outstanding. It's durable, rigs where you want it and uses the batteries you choose all in a nice compact package.
I worked as a 1st Assistant Camera/Focus Puller for 15 years. When LCD's came on the scene I quickly discovered that they are not true for focus. They have made advancements but I still only trust a CRT monitor for focus. Hopefully your using the P+S Technik 35 adapter. If so, you can trust the focal plane mark for measuring for focus.
I am using a Sony 9L3 SD CRT 400 res monitor(~$1200 with Portabrace) with my HVX. I put it to the test on a short narrative film style shoot with the HVX lens only and every shot was focused the way we wanted. We utilized the focus assist, viewfinder, LCD, CRT and general tape measuring(even though the HVX doesn't have an accurate focal plane) all in combination to acheive our goals.
Conclusion: LCD's are an essential tool in production but I do not rely on them for focus or exposure.
Hope that is of value to you.
