On camera LCD Monitor
I keep reading about people with 35mm adapters using LCD monitors to flip the image, and also stating they are pretty inexpensive, some saying from $50 to $200.
***WHERE DID YOU FIND THESE PRICES?*** And how do they work? Component out? I have an FX1 Thanks! |
I've got the same question. I don't even know what term on ebay to search to find them.
Why bother with Ebay. Try http://www.ikancorp.com/products_monitors.htm
I just got 1 7" from Varizoom - the res sucks for focussing the H1,
I may give Ikancorp a try - Good resolution Chris? have you tried them? thanks, J |
#5 |
monitoring
An idea I have for shooting, but first.
On the DVXuser website, under diy forum, I saw a 35mm adapter and the guy simply used a mirror attached to the lcd to flip it back correctly for viewing. Tilt the monitor and look at the mirror to view it corrected. As I can't afford to buy a portable HD monitor for the type of recording that I'm doing, just for family stuff and some work for a TV station that I do as a volunteer, I was thinking about the portable DVD players. You can get a 10 in portable dvd player for well under $200 dollars. It has a AV out and in on the system. Use a audio to RGA plug or Audio to audio plug and you should be able to use it as a larger viewing monitor for recording... Why? Because it's just too much of a hassle to lug around your big screen hdtv set with you. :) |
#6 |
John!
What do you think about this solution? : http://www.rowe.at/de/images/stories...2VF_promo.html robert |
#7 |
Denver:
http://www.denver-electronics.com/pa...bMenuguid=8628 and Lilliput: http://www.ex-audio.net/shop/index.p...a&filter_id=27 There is also Vitek wich is very cheap but i couldn't find their home. Googling gives many russian links so maybe their brand. and for DIY: http://www.aeicomp.com/LCD_Modules.a...LCD%20Monitors |
#8 |
How about DVRack?
Will the latest patch allow you to flip the picture?
