Reference Monitor & HVX at DVinfo.net
Old February 11th, 2006, 07:35 PM   #1
I did a search, didn't really come up with much on this...
I'm putting together an HVX package and I'm trying to figure out the best reference monitor to get that dosen't break the bank. I looked at the Pana 17" LCD, but the fact that it's an LCD makes me a little leery, not to mention the price (though the waveform is attractive). I was also looking at 9" 800+ line SD monitors with component-in.
What do you guys think? Any particular recommendations? Less than $1000 would be nice...
Matt Irwin
DP / matt.irwincine.com
Matt Irwin is offline   Reply With Quote
Old February 11th, 2006, 08:47 PM   #2
JVC makes their 10" HD monitor which is around $1100...problem is that it needs a 4 or 5 hundred dollar component card to take HD signal.
For $1500 or so though, I'd be very inclined to check it out.
My Work: nateweaver.net
Old February 12th, 2006, 08:02 PM   #3
Nate,
That sounds like a great setup. I looked on B&H and didn't see it. It's an HD monitor or a high res SD monitor?
I would be upgrading from a nearly 10 year old 9" Panasonic (S-Video or BNC only, no 16:9) that will barely hold it's calibration for a week. So... pretty much anything is an improvement.
Just to check, could the monitor that I already have be used with the HVX if needed (I may have to buy a new monitor at a later date)?
EDIT: found it on EVS- this one, right? http://www.evsonline.com/merchant2/m...Code=DTV100CGU
Matt Irwin
