Still having major monitor problems
I really need a monitor for my editing in HDV, but first choise was the panasonic BT-LH1700W HD/SD LCD Monitor, but the problem is that LCD is not accurate colors.
So my next choice was a CRT VC DT-V1910CG Hi-Res/HD Monitor, but I was told that JVC does not make true CRT and they have a coding on the screen that does not show accurate colors. Now I am told that Sony is really the only true CRT because of the Smpte, but they don't make CRT anymore. What do I need to get to get an accurate HDTV monitor so I can color correct and also make any other color changes and eventually transfer to film. Anyone? I have had this problem for 6 weeks now and i REALLY need a monitor ASAP. |
#3 | |
#4 | |
Take another look at the specs on the JVC monitors. They claim they use SMPTE/EBU colourimetry. They are true CRTs, contrary to what you say you were told, but it's true that they may not use the same phosphors as the Sonys. But for all practical purposes I'm not sure how much difference that really will make. Remember too that 99.99% of people viewing HD video will be using LCD or Plasma monitors, not CRTs. If you're transfering to film, I would think the transfer should be calibrated anyway if you provide a colour reference.
Good news, Cousins! This week's chocolate ration is 15 grams! |
#5 |
To be honest, I am thinking abiout just getting a lcd for field and strudio and if I ever transfer to film I will go and get it color corrected somewhere professional.
What's you think of the panasonic HDV 17"? |
#6 | |
#7 | ||||
Now there may be quality and design differences between different brands and price points, but I doubt that JVC is really inferior to Sony monitors at the same price points (well JVC is generally cheaper, so it's kind of hard to compare... presumably Sony is better if you assume that more expensive is better). Quote:
The BVM series is their highest-end monitors... they go up to like $65k. They have the PVM series, which is more reasonably priced. You can get them with SMPTE C or EBU phosphors. Some have P22 phosphors, which are not the standard (and may vary from batch to batch according to Sony literature). Ikegami, Panasonic also make monitors with SMPTE C phosphors. JVC used to but no longer does I believe. EBU is for Europe/PAL, SMPTE C is for North America/US. For HD, the phosphors are supposed to conform to the 709 standard, which is a compromise between EBU and SMPTE. I do not believe any manufacturer currently makes monitors with 709 phosphors. Quote:
eCinemasys is coming out with an interesting LCD that's geared towards being a "reference-grade" LCD. It tries to squeeze the most out of a LCD panel that's possible. The guy who designed it, Martin Euredjian, bashes competing Sony products in this thread: http://tig.oktobor.com/pipermail/tig...ch/006542.html And from the previous post: Quote:
#8 | |
http://www.dvinfo.net/conf/showthread.php?t=50921 |
#9 |
On the flip side, it may not be really worth that much to spend a lot of money on a HD monitor.
A- NTSC = never twice the same color. In practice, there will be huge variation in what the audience sees so a little color inaccuracy won't make a difference. B- Even if high-end places, their setup may not be all that accurate. I've seen places with $100k+ in equipment and they don't do simple things right, like avoiding the use of incandescent lighting, or not grading in darkness, or avoiding reflections of lights on the monitor. |
