Recommended SD Cards for External Recorder
I've just bought the Blackmagic Design Video Assist monitor and recorder. Having done a couple of tests it seems that I need to buy faster SD cards for recording onto it. Using what I have at the moment (SanDisk Ultra 64GB SDXC UHS-I 80MB/S Memory Card Class 10) I found that recording to ProRes 422 Proxy produced a file at 76 Mbps bit rate. ProRes 422 LT came out at 170Mbps. A 41 second file was 750MB LT, whereas the Proxy version was about 1/2 the size at 380MB.
As this will mostly be a back up file to the SD card in the camera, I would like to keep file sizes down but get the best resolution possible. I did notice that there was issues with playback, hence the need to get faster cards. I tested by panning around the room at a 'normal' speed. The lower quality Proxy file played back in my editing software without glitches and seemed smooth, but the LT file started to stutter after about 3 seconds. It was unusable. I don't really understand card speeds but have read that at least 95MB/s is recommended. I have also seen that SanDisk do one that does 300MB/s, but sells for over £100 for 64GB card!! Can someone please advise me what I need to buy. many thanks |
#2 | |
Re: Recommended SD Cards for External Recorder
Blackmagic have a list of recommended cards on p 29 on the user manual (June 30 2017 update). It's in table format and easier to read than the text only version below:
I'm using cards from this series and they seem to work OK in a Video Assist 4K, but I'm doing mostly 1080 HD not 4K on it. PS: Check you have the latest software - it should be v2.5 |
Thanks for that, I can't believe I missed that in the manual.
