Is 14.4 volts OK for 5 volt monitor? at DVinfo.net
Old February 8th, 2016, 12:58 AM   #1
I've got a Marshall V-LCD51 5" monitor that has a 5v marking on it. The instruction manual says it takes anywhere from 5v to 12v. I want to get a Swit D-Tap 14.4 volt battery, which is stated to work with my camera. If I plug my 5 volt monitor into the 14.4 volt D-Tap connector, could that damage the monitor?
Ken Hull is offline   Reply With Quote
Old February 8th, 2016, 12:13 PM   #2
Re: Is 14.4 volts OK for 5 volt monitor?
I don't have direct experience with that setup, but generally speaking you don't want to exceed the rated voltage. Over rated amperage is ok since it just draws what it needs.
Stephen Brenner is offline   Reply With Quote
Old February 8th, 2016, 12:34 PM   #3
Thanks Stephen. Based on your advice, plus what others have told me, I'm going to skip the D-Tap idea, and just use the small battery made for the monitor.
Old February 10th, 2016, 02:55 PM   #4
A straight cable would potentially damage the monitor. You would want to get a special cable with an inline transformer to convert the voltage from 14.4 volts down to the rated range.
Daniel Epstein is offline   Reply
