MustHD 7inch monitor/input?
im currently using an Ikan 7inch monitor with my ex1r. although its very sharp, its much brighter than my lcd, so i have to first set my iris before i can reference with the ikan, otherwise, going off the ikan, id have a very dark picture.
ive heard the MustHD 7inch is worth a look. input welcome. are there any good 7inch monitors that give good color and match well with the LCD |
Re: MustHD 7inch monitor/input?
Jim,
I use a low end Marshall and a 7" Must HD. Just like you said, out of the box the Marshall is too bright so I knock it back. Big difference in quality between the two monitors. The Must HD has a default setting that is closer to the LCD but not perfect. I think ALL field monitors should be adjusted correctly so I am not sure what your after? Once you adjust your Ikan you should be fine? Why would you set iris instead of adjusting the monitor? Since you have an Ikan I do not know if a you would realize a big net gain by spending the top dollar for the expensive MustHD. They are good monitors, but worth it? Maybe? I am glad I have one, but very expensive. And don't forget to look at the al la cart pricing on everything Must HD, including the SDI input. Steve
www.CorporateShow.com Been at this so long I'm rounding my years of experience down...not up! |
I don't think Price: $399.00 is high
The MustHD_1280x800 monitor is really good and it has many functions including a Zoom that can make adjusting focus easier. I also use an Atomos Ninja II and the (internal & external) recorded images are closer to the MustHD than the GH4 or A7s LCD. The SmallHD 7 inch monitors run from $599 to $2499 with the same resolution and there is the superior Shogun at $1999 with an included recorder. |
Gentlemen,
I just got a big laugh at myself. My post above was a brain malfunction. I do not own a MustHD monitor. I am not even familiar with the line. I have the more expensive SmallHD AC7. I read MustHD and I thought SmallHD :) Sorry about that. My post will make more sense if you change my comments to SmallHD. Steve
