Monitor for Camcorder help please - Page 2 at DVinfo.net
Old January 26th, 2013, 04:40 AM   #16
Re: Monitor for Camcorder help please
The OP listed a monitor that was 7", but, IMO and of far more importance, a higher resolution!
7" HD-DSLR LCD Monitor w/ Advanced Video Functions - LCD4Video
Most of the 'alternative' monitors mentioned in this thread are 800x480 native resolution; that whilst slightly better than the built in screen of the host camera, are hardly going to help improve tasks like focusing ect...
The OP's 7" is higher res @ 1024x600 meaning more pixels and therefore higher resolution. More leads to higher resolution = better chance of getting a good focus in the field.
All of the monitors mentioned in this thread down-sample the incoming image from the camera to the native resolution of the panel. The OP's monitor option at least gives the option to pixel map which, as someone else mentioned, does mean you don't see the full picture, does at least mean checking focus around the centre point is possible.
The field monitor market is set to explode soon, with the arrival of Full HD (1920x1080) panels. You can already find these in use on some of the later mobile phones and tablets (LG, Samsung ect...)
I have a 7" 1024x600 monitor now and the only complaint I have is poorer viewing angles, but understanding it's limitations is key to getting good results. It using very cheap to buy Sony NP type batteries too.
I will upgrade though, just as soon as the higher res panels filter down to the semi-pro market.
It's very interesting times...
Pete
My camera setup
https://www.dropbox.com/s/5re9dhebvz...17.06%20ED.jpg
Peter Kay is offline   Reply With Quote
Old November 9th, 2013, 07:51 PM   #17
Originally Posted by Nate Haustein View Post
This 5" Marshall is without question one of the best deals you will find: Marshall Electronics V-LCD51 5" Monitor / V-LCD51-LPE6-BK
5" is more than large enough - 7" is just too big for an on-camera monitor in my opinion. Additionally, the resolution is identical in most of the 5 and 7" models you are looking at, 800x480. It has HDMI input, peaking, false colors, pixel-for-pixel and a Canon LP-E6 battery mount included. There are also about 7 or 8 other battery mounts you can choose including Panasonic and Sony.
Some of the lower end Marshalls are sourced form the same place as the Lilliputs. Same goes for the lower-end Ikans. You'll find that certain models look strikingly similar... This 5" I linked to above is simply a better quality monitor than most being discussed here. I own two and would recommend them.
I apologise for bumping this thread, but does anyone know the approximate battery life I'll get with the marshall V-LCD51 using canon LPE6 batteries? I might be getting one for my 5D and would like to know how many batteries i would need to get along with it. Thanks
Premiere Pro & Vegas user | freelance filmmaker
Vimeo: https://vimeo.com/donaldong
Donald Ong is offline   Reply With Quote
Old November 10th, 2013, 11:28 AM   #18
With a normal 1800mah LP-E6, the monitor should run for 1:20 or so. I have a bunch of cheapie LP-E6 batteries rated a little higher at 2800mah from Amazon/eBay. They cost about $10 each and work just fine. You may get a little more time out if them. The PhotoPro dual LP-E6 charger is also really great - the one with the LED display.
Nate Haustein PXW-FX9 / FCPX
www.flightcreativemedia.com
Nate Haustein is offline   Reply With Quote
Old November 10th, 2013, 07:18 PM   #19
Wow only 1 hour and 20 mins? that sucks. :/
Is the 1:20 with peaking and zebras active? Or will that reduce it even further?
Old November 11th, 2013, 12:15 AM   #20
Zebras and peaking certainly can't help...
Perhaps you should be looking into the Sony or Panasonic battery options, as a higher capacity battery would last you all day long. The NP-F9xx series batteries are cheap and easy to obtain, and free chargers come with many third party packages.
Old November 11th, 2013, 08:46 AM   #21
Yup that is definitely a consideration..I already have third party NPF-970s for my lights and could get more...but the marshall V-LCD51 only comes with the canon battery mount right? Or is there a sony option?
Old November 11th, 2013, 09:27 AM   #22
Yeah, there's a bunch available - maybe 7 or 8 different options. Not sure how you source gear in Singapore, but they're all listed on B&H.
Old November 12th, 2013, 08:19 AM   #23
Ah yes, you're right. Missed that. Any idea how many hours I'll get on an F970?
Old November 12th, 2013, 10:20 AM   #24
6600mAh divided by 1.25 Amps = about 5 hours
I think my math is correct...
Old November 22nd, 2013, 05:52 AM   #25
Ah ok. thanks a lot, you've been a great help!
