Laptop monitor at DVinfo.net
Old June 13th, 2012, 10:42 PM   #1
Laptop monitor
Just wondering....... is it possible to use a macbook pro for video monitor?
Michael Thames is offline   Reply With Quote
Old June 14th, 2012, 05:44 AM   #2
Re: Laptop monitor
It's easy with an HDV cam via firewire - the problem is there is significant latency. 2 second delay.
I use it occasionally with OnLocation or even QuicktimePro.
I would think latency would be present with any hardware solution, as well.
Mark Ahrens
www.heritagefilms.net
Mark Ahrens is offline   Reply With Quote
Old June 14th, 2012, 05:49 AM   #3
Re: Laptop monitor
I assume you mean a monitor for a live camera shot. Your Macbook has specific input ports: USB, Firewire.
The quality of the result and color issues of computer screens aside:
1)Your camera has recording formats and output ports.
2) By connecting a camera output port to the computer or device that interfaces to the computer, running the camera in a format that puts a signal on that output port, and running software that captures video on the computer's input port, you will have conceptually monitored the camera video on the computer display.
For example, DV and HDV are camera recording formats that can be transmitted over Firewire. Using one of those camera modes, a FIrewire cable to the Macbook Pro and running QuickTime Pro, iMovie, or FCP will monitor your video and audio (with a slight lag)
Other formats such as Component and SDI require some conversion devices and may or may not be able to hook up to your particular model laptop.... eventually it begs a different question: Given the price of HDMI and SDI field monitors from Marshall, SmallHD and others, is it worth it to try and use the laptop?
Old June 14th, 2012, 05:41 PM   #4
Re: Laptop monitor
Thanks les and Mark, I have an Ikan monitor for my HX-A1, but the thought occurred to me my computer sits around doing nothing, and the picture is better on the Macbook. How do I set up my computer to use as a monitor, if you don't mind my asking?
Old June 14th, 2012, 05:51 PM   #5
Re: Laptop monitor
Connect it with a firewire cable . . .
I use OnLocation part of CS5 suite - discontinued in 5.5 and 6.
or . . . Quicktime Pro -> new movie recording (go to preferences to select the XH as the input - Camera must be on and in record mode) - you can actually use it to capture direct to your hard drive in HDV format. It's a hassle starting and stopping, though. Making a new Movie each time.
Mark Ahrens
Old June 14th, 2012, 09:10 PM   #6
Re: Laptop monitor
Originally Posted by Michael Thames View Post
...I have an Ikan monitor for my HX-A1, but the thought occurred to me my computer sits around doing nothing, and the picture is better on the Macbook. ...
How are you hooking up the Ikan? If it's composite, then yes, the HDV over firewire into a Macbook should be an improvement. If you are hooking up the Ikan with component video, your getting the HD signal and I'd think it would be a decent image.
Old June 15th, 2012, 09:29 AM   #7
Re: Laptop monitor
Mark, this doesn't capture video onto the hard drive right?
Old June 15th, 2012, 09:31 AM   #8
Re: Laptop monitor
Yea it's a good image for sure, but it's a smaller monitor compared to my 15 inch Macbook.
Old June 15th, 2012, 10:58 AM   #9
Re: Laptop monitor
...this doesn't capture video onto the hard drive right?
You need not capture to disk if you don't want ti ... QT just gives you a live feed
Old June 17th, 2012, 10:02 AM   #10
Re: Laptop monitor
Thanks for all your help guys!
