669GL-70NPCH Replacement Battery? at DVinfo.net
Old January 17th, 2012, 02:57 PM   #1
Hello All -
Some time ago, I purchased the Lilliput 669GL-70NPCH. It came with two batteries. One has been performing just fine; the other won't hold a charge at all, and in fact, gives me error flashing when I try to charge it. I've searched around and have only been able to find one place that sells the exact same thing, on Amazon, by searching Pinecom YSD-12180. Rightly so, as mine died without ever being able to hold a charge, it has one review warning about how terrible it is. I'm wondering what alternatives there are to replace the battery pack for this monitor. I've been looking around, but I'm not sure which to use, and when I search for batteries for the lilliput, none of them look similar, and some even have different cables for attaching to the monitor. Any help would always be greatly appreciated.
From the battery:
Input: 12 6 VDC
Output: 12. 6-10 8VDC 1800mAh
I'm not even sure that's what I need.
"Make the most of yourself, for that is all there is of you." R W Emerson
RED ONE MX | 5DmkIII | SD744T | SD442 | Sennheiser MKH416 P48
Brian Maurer is offline   Reply With Quote
Old January 19th, 2012, 08:39 AM   #2
Re: 669GL-70NPCH Replacement Battery?
IIRC, the Lilliput is the same or very similar to the Jag35 monitor (and others like it.) I don't use the battery that came with it, but went another route.
I had a plethora of Sony NP-970 batteries laying about and wanted to use them for everything. I looked online and bought an IKAN Sony battery adapter. (AC-107S, I think..) It plugged right into the monitor and was easy to Velcro to the back. The batteries lasted a while for me, actual times, I don't know... The Sony style generic batteries are relatively inexpensive. You might look at that as an option.
P.S., BTW I did the same exact thing for my Sign Video ENG-44 mixer. Works like a champ and I can easily mix and match batteries.
Bob Krieger is offline   Reply With Quote
Old April 2nd, 2012, 11:20 AM   #3
Hi Brian,
I've got the same exact monitor. It's worked great until some wierdness Sat night where the Brightness would turn itself up by itself.
It's great to find someone else that own's this monitor! You charge the battery with the battery turned on correct? Will the light turn green when completely charged?
Anyway I'd love to find a replacement battery too since I'm SOL if this one bites it.
so lurking....
Nashville TN using Canon 5D MK3, Canon 550D, RODE SVM mic, 70-200 f2.8L II IS, 24-105 f4L IS, 50 and 85 f/1.8, Vegas Pro 11, Zoom H4n, Blackbird, Lilliput Monitor, Lightroom
Harry Simpson is offline   Reply With Quote
Old July 2nd, 2012, 11:31 PM   #4
I just bought a 669GL-70NP/Y. It comes with a big, heavy 12V DC battery that's over 6" long. I've seen some Lilliputs that take Canon or other small batteries. Does anyone know if I can there's an adapter available for my Lilliput model that will take a smaller battery?
This is the model I have--if you click on the 4th photo you can see the battery I'm talking about.
Jim Newberry is offline   Reply With Quote
Old July 3rd, 2012, 11:46 PM   #5
Ah, it looks like I found it:
MG1 Concepts LP-E6 Battery Plate
CANON LP-E6 Battery Plate [CANON LP-E6 Plate] - US$12.00 : COOLLCD.com
Old September 17th, 2012, 02:22 PM   #6
What about this? I just got the same monitor and was going to use this as back-up.
David Gillespie is offline   Reply
