Dell U2311H or Dell ST2220T at DVinfo.net
Old July 21st, 2011, 02:45 PM   #1
Hiya folks,
Here's the scoop. I'm looking at these two monitors. One of them is a touch screen which would come in handy for me. I'm going to be travelling and editing as I travel so my secondary monitor being a touch screen would have a lot of different applications that I could use. The thing is, I don't want to give up too much when it comes to the display. I was wondering if anyone has had some experience with these monitors, primarily the touch screen, and if you can provide any feed back. Thank you very much in advance.
Scott
Here are the technical specs:
ST2220T
Diagonal Viewable Size:
21.5” (54.61cm)
Panel Type:
IPS (active matrix –TFT LCD)
Maximum Resolution:
1920 x 1080 at 60 Hz
Contrast Ratio:
1000 : 1 (typical), 50,000:1 (dynamic)
Brightness:
250 cd/m2 (typical)
Response Time:
8ms (gray-to-gray) with overdrive
14ms (gray-to-gray) without overdrive
Viewing Angle
178° vertical / 178° horizontal
Color Gamut:
82%2 (100% sRGB coverage)
Color Depth:
16.7 million colors
Pixel Pitch:
0.248 mm
U2311H
Display
58.4 cm (23 inches)
Aspect Ratio
Widescreen (16:9)
Panel Type, Surface:
IPS (In-Plane Switching), anti glare with hard coat 3H
Optimal Resolution:
Contrast Ratio:
1000 to 1 (typical), 10,000:1 (dynamic)
Brightness:
300 cd/m2 (typical)
Response Time:
8ms (gray to gray)
Viewing Angle
(178° vertical / 178° horizontal)
Color Gamut:
82%*
Color Depth:
16.7 million colors
Pixel Pitch:
0.265 mm
Display Type
Flat Panel Display
Scott Thibodeau is offline   Reply
