connecting a monitor for color correction at DVinfo.net
Old August 16th, 2005, 09:54 AM   #1
i just received a nine inch sony monitor and i have no idea how to connect it. basically I got two cables don't know what to do with it... on the top of it i have to get the project done by tomorow evening!
thanx for your help
Yohann Kouam is offline   Reply With Quote
Old August 16th, 2005, 10:08 AM   #2
There's three places you have to look at.
Final Cut- set the canvas and viewer to fit to window or smaller. make sure they aren't over 100% zoom.
make sure final cut is sending video out to firewire... it's in the preferences somewhere.
2- Your deck/camera- needs to be able to convert DV-->A/V out. Nearly all equipment does this.
It needs to be set to convert DV-->A/V out, not the other way around. This is a menu setting while the equipment is in VCR mode.
3- Attach the yellow RCA jack from your camcorder's A/V cable to the back of the monitor. You may need a RCA-BNC adapter for most broadcast monitors.
Or use S-video (may be called Y/C on the monitor).
Old August 16th, 2005, 10:13 AM   #3
thanx glen. two other question. i got two connections on the monitor: "IN A" and "IN B", on which one do i connect the yellow cable? and secondly what about the red cable isn't the one i'm supposed to get the sound back with?
Old August 16th, 2005, 04:03 PM   #4
ok i just connected the deck vie the s-video cable. i got the display on the monitor but i don't have fcp display neither on the cam nor on the monitor.
unfortunately since i got my boss's sh...y samsung camcorder i don't have the dv to a/v mode so i guess it's just screwed...
Old August 16th, 2005, 04:18 PM   #5
What version of FCP are you running, if you're running ver 5 you need to go to the view menu and set external video to all frames
"We've done the impossible, and that makes us mighty."
Nate Schmidt is offline   Reply With Quote
Old August 16th, 2005, 04:32 PM   #6
i'm running with verson 3
Old August 16th, 2005, 04:48 PM   #7
by the way i was told that decks such as camcorders were not totally reliable and therefore calibrating with FCP is necessary. how do i calibrate with FCP?
Old August 17th, 2005, 03:04 PM   #8
i finally got a right deck but the calibrating part is giving a real hard time. i followed the insctuctions from the FCP manual but it doesn't add up, any trick for that?
Old August 17th, 2005, 03:18 PM   #9
Does this help?
http://www.videouniversity.com/tvbars2.htm
Old August 17th, 2005, 03:54 PM   #10
it looked damn interesting unfortunately i'm running PAL...
Old August 17th, 2005, 04:00 PM   #11
Hmm, is it different? FCP should be able to give you PAL color bars (under effects > video generators) and I always assumed the procedure to calibrate would be the same. I also found this which implies as much, but honestly I just don't know...
http://www.dvinfo.net/conf/archive/index.php/t-544.html
Let's see if I can get Rob's attention to this thread, since that ancient one was initiated by him...
Old August 17th, 2005, 04:32 PM   #12
i'm not positive but i think they're different
