#46 |
Re: Sony Monitor for Alpha SLT/DSLRs
Can someone tell me a height measurement from bottom of hot shoe adapter to the top of the monitor?
Thanks! |
#47 |
5 5/8" with the adapter straight up. Can't imagine you're run it that way though.
#48 |
#49 |
I should add that with the arm I mentioned you are able to position the monitor directly next to your camera.
"The horror of what I saw on the timeline cannot be described." |
#50 | |
When you say "Can't imagine you're run it that way though." what do you mean? I suppose I would be angling it back a few degrees? Maybe that would make the clearance. Thanks, Chris |
#51 | |
Also I saw this item in another forum: A couple of crappy pics of mounted monitor: Sony SLR Talk Forum: Digital Photography Review (the author's title, not mine) It's a Manfrotto 430 11" Long Plate Double Camera Platform. It looks a little longer than I would like, but I'll look for something similar, but a few inches less in length. EDIT: Upon further thought, I don't think that 430 or similar device will work for me. It attaches directly to a tripod via a 3/8" mount. I want my video head on the tripod with the camcorder (plus mic) attached to the head, and the monitor mounted to the tripod in such a way that panning the video head doesn't pan the monitor. So I think Jeff's articulating arm suggestion is the best, or maybe only, option. By the way for anyone reading this who is considering ordering the monitor, I ordered it last night from Amazon for $339.26. It is still that price today as I write this. That's about the best price I have seen. |
#52 |
#53 |
I don't know what could be a better solution for the monitor. It was a sweet setup, and very impressive looking. I agree the bar is not so hot. I have a much larger one, and have two heads on it for two cameras, it is convenient, but how awkard and heavy it is..
#54 |
Sorry to be-labor my questions about mounting the CLM-V55 on a tripod, but I have another question about Jeff's articulating arm method.
I have researched the Manfrotto Super Clamp and Magic arm and now understand their purpose. They are bigger/heavier than I need for the monitor, but assuming for the moment I use them or smaller versions of the same concept, this is my question: I understand how the clamp attaches to the tripod, and how the arm attaches to the clamp. The monitor arrived today and now I see that I see it, I don't want to mount it directly via to a tripod stud. I will want to use the shoe mount adapter that came with it because that is what provides the tilt capability. What I don't understand is what piece has a shoe mount on it that the monitor's shoe adapter will attach to. Jeff, in addition to the arm and the clamp, in your earlier post you mentioned an "extender" and a "shoe mount for the end of the arm". Can you describe those for me? Which piece has the shoe that the monitor mounts on? And what is the sequence of the pieces after the arm is attached to the clamp? (Extender attaches to arm and the the shoe adapter attaches to the extender and the monitor to the shoe adapter -- or do I have it backwards)? Sorry to be so dense, but I'm having a hard time visualizing what I need. If the small local photography shop can't fix me up, I will need to order something from B&H, so I want to understand what to order. So if Jeff or anyone else can provide some guidance, I would appreciate it. Thanks. |
#55 |
The shoe mount adapter has a 1/4 20 threaded socket in the base.
You should be able to screw your tripod into it and have the full benefits of this mount. |
#56 |
Thanks Kirk, now that you mention it, I see the tripod socket in the end of one of the adapters (but not the other one - I'm not sure which adapter I need to use yet). But I have a video head mounted on my tripod's threaded stud, with the camcorder/quick attach plate mounted on the head. So that leaves no place to screw the monitor's adapter onto? (I would mount the monitor in my Sony camcorder's AIS shoe (with cold shoe adapter), but I have a Rode microphone in the shoe.)
I don't want to use a second tripod for the monitor. I will be using the whole setup at my grandchildren's elementary school plays and programs where my tripod already takes up more floor space in the crowded gym than I would like (or the parents of the other kids would like). |
#57 |
I missunderstood, thought you wanted to mount it to the triod.
Do a search for Tecnec brand mount PD-05020 or something similar at the usual vendors |
#58 |
There are plenty of monitor mount options out there. You need something double the shoe mount or attach to the tripod leg. Here's a couple more options.
Welcome to Cineroid Homepage! |
#59 | |
Thanks for your advice. I will look for a product like the Tecnec and will also look at the Cineroid link you posted. |
