Need advice: Simple live playback setup at DVinfo.net
Old October 12th, 2010, 07:03 AM   #1
Hi guys
I've recently edited together footage for a theatrical production. It is pretty simple with only 3 cues but it starts and ends the show so is very important. It is video and audio synced and the audio will need to be routed through the sound system. We originally had a DMX cued system arranged but have canceled as it can't output the audio as required.
They can't afford me or a separate op to cue just 3 cues for every performance, so the (Deputy) Stage Manager will do it. Therefore I need a very simple system that can playback instantly on cue from a laptop. Ideally it would work with the projector acting as the secondary monitor and the laptop monitor showing the cues etc.
I'm thinking along the lines of an itunes (ie simple) interface where the DSM can just select the cue and then hit space bar to play it instantly. I considered tape but as the timing is critical this could be tricky and I'm not sure if the DSM will want to be cuing it up whilst concentrating on other things.
I am familiar with high end systems like Catalyst but that is overkill for this. Budget is tight.
Many thanks!!!
www.mikemarriage.com
Mike Marriage is offline   Reply With Quote
Old October 13th, 2010, 03:41 PM   #2
Hi Mike,
Have a look at QLab Figure 53 | QLab | Live Show Control for Mac OS X
We have started using it for shows and so far have been happy with it.
If you already have a mac book it will probably fit within your budget.
It can do far more than simple video playback - but that is all we are using it for at the moment.
Lighting Cameraman - www.rotahead.com.au
Sony PMW-350, FS7, JVC LS300, BMPCC, BMPC, GH5 & a shed full of lights,dollies, jibs
Rohan Dadswell is offline   Reply With Quote
Old October 14th, 2010, 04:05 AM   #3
This probably isnt helpful to your particular situation, but for live stuff i use liveworship or propresenter. Its funky since both are designed to be church software, but both are great for having a library of video clips that you can play instantly on demand in order or just nonlinear with a click.
I already own liveworship for my church and propresenter for my mate's church, so the price isn't an issue as it would be if you were buying it cold.
It sucks that they've intentionally crippled itunes for dual head video playback. Its more than capable of doing it, if they'd let it. Then you could have your videos "like itunes" actually be in itunes!
cheers,
-a
Andrew Dean is offline   Reply With Quote
Old October 14th, 2010, 05:40 AM   #4
Thanks guys, really appreciate the input. I'm taking a look at the demos now.
Any other ideas welcome as I don't need to buy just yet.
Old October 14th, 2010, 08:36 AM   #5
If your needs are really that simple, you might be able to do this with VLC player, which is free.
videolan.org
Arnie Schlissel is offline   Reply
