Great article about critical monitoring at DVinfo.net
Old July 17th, 2010, 07:58 AM   #1
ProVideo Coalition.com: TecnoTur by Allan Tépper
Brian Tori is offline   Reply With Quote
Old July 19th, 2010, 01:13 PM   #2
Thanks for posting this. The YUV-RGB difference is important to know about.
Old July 19th, 2010, 01:26 PM   #3
Thank you for posting this. It is perfect for me because I use Premiere CS5, displayport from my Quadro FX3800 and a 10bit Eizo CG243W. I just want to know if I must add a YUV-RGB effect on the timeline to enable Premiere's realtime conversion.
Old July 19th, 2010, 04:46 PM   #4
The photo shows a MBP w/the mini-DP. But does anybody know FOR SURE if it is outputting 10bit RGB? I read further into the article that...
.... "Even though DisplayPort and HDMI can handle either YUV or RGB, so far in my experience, all of the computer implementations of DisplayPort handle RGB-only, and any HDMI computer implementations that Greg Staten has seen currently handle RGB-only. Although a driver could be written to send YUV over these computer outputs, I have two reasons why I believe maintaining them as RGB makes more sense...."
Reason I ask this is because the reply I received back from nVidia was that NONE of their G-series cards are 10 bit enabled...only their Quadro series cards from the 1800 on up...including the CX. The MBP uses the GeForce 330m card.
Confusing to say the least.
Andrew Clark is offline   Reply With Quote
Old July 20th, 2010, 09:15 AM   #5
You're welcome. It's nice to know that finally, Premiere is handling the proper conversion on it's own. I just upgraded to CS5 in combination with a GT240 graphics card. I like having the ability to connect straight from my card to my HDTV preview monitor. This eliminates the added expense of buying an in/out card.
Old September 5th, 2010, 09:46 PM   #6
Interesting stuff. The world of professional monitoring is actually quite a lot more complex than I ever thought it could be. Now I see why they have conferences on it every year at the hotel I work at. Glad I'm a CS5 user though, now it's time to start saving up for a nice monitor.
Paul Digges is offline   Reply
