Marhshall V-LCD651ST issues at DVinfo.net
Old March 22nd, 2010, 03:05 AM   #1
Hello,
I recently bought a marshall V-LCD651ST with sony battery adapter.
When i switch the input signal on the camera, for example from 1080p25 to 1080i50 the monitor will lose its signal and shows the "no signal" message.
When i restart the monitor i cannot select the sdi input anymore, only composite and component are available then.
I need to unplug the sdi cable, switch the monitor off for 10 sec. then switch on, plug the cable and it finds the signal again.
Is that normal with the monitor?
Robert
Robert Eder is offline   Reply
